weishi
gary17
hey
i have just started using the weishi and im struggling on a read out on a old everite watch.
The pics below show consecutive screens.
I am presuming its beyond help unless someone know something i am missing.
I have moved the adjustment timer on the balance and it does not seem to make a difference.
cheers
gary
16 minutes ago, gary17 said:
I have just started using the weishi and im struggling on a read out on a old everite watch
The instrument is doing his job correctly, telling you this piece at the minimum needs a complete, accurate service.
1 hour ago, gary17 said:
hey
cheers
gary
You are not the only one struggling to interprit tg graphes.
Edited by Nucejoe
Poor amplitude, fluctuating daily rate, it is not running happy.
Hi Gary I am afraid there is no point putting a duff watch on the machine when trying to understand it. Out a watch on that you know its characteristics and that it is a good one that way you know the machine works and you know what you are looking at. So once having acertained how it works and able to analyse its out put then introduce a watch like the everite and analyse its out put according to the instructions. Its a new toy and will take a little time to understand.
Well you have a range of -102 to +3 seconds/day and I would say that the 'adjustment timer' (more correct term is regulator) is working fine.
If you're expecting a nice clean trace, that will only come with a strip-down, inspection and assembly with correct oil in correct amounts. There are no shortcuts.
Anilv
34 minutes ago, StuartBaker104 said:
Assuming that the watch is nearly fully wound and you've set the lift angle correctly for this movement then the amplitude
Worth to remind that even without bothering to set lift angle, or having a "large" discrepancy of 5°, the amplitude value is not greatly affected and will be accurate enough for making a go/no to call.
Besides the obvious lack of amplitude, I think an important thing to check is to see if stud is loose in stud carrier. Other things to look out for are loose index pin and boot, index, harispring either at collet or stud end, shock assemblies, as well as condition of the pivots.
Edited by CaptCalvin
I'd think anything loose there would show an irregular beat error (spacing between the lines).  That really looks like the good part here.
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
