Cleaning the pallet fork and balance
vext01
Hi everyone,
I recently read on a forum that you should not clean the pallet fork or the balance with IPA alcohol.
I knew that you shouldn't use IPA on the pallet fork, as it removes the shellac, but why not the balance? And what would you use on these components instead if you were on a budget?
I've recently serviced a Vostok movement where I *did* clean the balance with IPA. No damage was done and the watch works fine, but now I'm curious.
Thanks
The impulse jewel on the balance is usually fixed with shellac too. One way to clean on a budget is to soak / brush / ultrasonic with lighter fuel, then a quick rinse in ipa to get rid of any residues and dry with a blower. Some people on here will not take the risk of getting alcohol on shellac, because it will soften it and dissolve it eventually, but the general consensus is that a few minutes contact don't hurt. Also, ammonia-based cleaners work well and are not too expensive. Then a rinse in alcohol is a good way to finish, because it drives off the water then evaporates without trace.
Just to remind once more that lighter fuel contains oils and fragrances that make it poorly suited in this time - it's formulated to burn not to clean.
Petroleum ether aka is actually cheaper in quantity and easily available.
jdm could be right about the "lighter fuel". it's a general term as far as I know, and some solutions may have oils etc. added which leave unwanted traces behind. That's why a rinse in alcohol after is a good idea. The purest ipa is not that easy to find though, and not that cheap when you find it.
For the record, this is the "lighter fuel" I use, 5 to 6 Euros for a 1 litre tin.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
