Jewel Hole Reamed Too Large
SparkyLB
I recently reamed a hole in a train bridge to .229mm.  I purchased a .230mm jewel and attempted to push it to depth.  I find the reamed hole will let the jewel pass through without a trace of friction.  It enters the top and falls from the bottom.  I measured the reamer on my JKA Feintaster and found it to be .2285mm.  I measured the jewel and it was right on the money.
Being quite inexperienced, I'm wondering what I might have done wrong.  Originally the original rubbed-in jewel was badly cracked, and despite my efforts, I could not straighten out the rubbed portion to use the same sized jewel.  I reamed that hole as above.
Should one ream only until the tool has done its business and then stop?  I think my repeated attempts to get a nice, clean hole resulted in a nice, clean OVERSIZED hole.  I didn't really have any way to measure the hole I reamed other than to measure the reamer.
Did I simply go a bit too far whilst reaming?
How big was the original rubbed in jewel? The material there is minimal, generally you'd ream well oversize to get outside the "rub in" area so there's some substance for the friction fit, unless you have a jewel that's just a hair over original. The reamers can go oversized, we're talking 0.01mm friction fit, best to have plug gages to check (I know nobody has them) or go almost all the way and test.
If your jewel falls right through, you must have made beautifully reamed oversized hole indeed..  I assume you used a jeweling set to guarantee uprightness? Any tilt while reaming will enlarge the hole, obviously.
It's too late now to say that you better practice first on a piece of brass or on a junk movement :)    You could measure the resulting hole size with a ~2.3x mm rod with a minute taper turned to it, and measure at the point it binds. If you have a lathe, that is. That's how I do it at least, since I don't have a set of pin/plug gauges.
Maybe you can recover by installing the next size up jewel, if you can get one?
13 minutes ago, oldhippy said:
When using a reamer always take your time and just a few turns and then test.
I assume you're using the seitz tool? I have a picture from the manual showing how you supposedly use the reamer. As already pointed out by oldhippie and my own personal experience do not follow the example shown in the manual. It is so easy to go past the hole size if you're not careful and end up with a  hole that is too big.
If you have a complete seitz set it should have the hole closing punches.
Then worst-case they also make brass bushings that can be inserted in and then you put the jewel into the bushing.
    in this kind of work,  you need the proper measuring tool:pulling-hair-out:      vin
Hi  That was a bit of bad luck but with any reaming or bushing it is prudent to regulary check the fit. Was it a tapered reamer and from which side did you make the cut. With clocks using a tapered reamer I cut from the inside, the Idea being that when you press in the bush its a tight fit due to the slight taper of the hole. In the case of over boring a clock you can fit an oversize bush and re cut carefully or turn down a blind bush to fit the hole and re drill and ream. This method can be used on watches as well but to be accurate you do need a jeweling tool for the job. There have been plenty of suggestions as to what to do for the best so I wish you all the best which ever method you choose.      Cheers
Nickelsilver, that's exactly what I did.  I removed just enough material to make a hole leaving no evidence of a previously rubbed in jewel.  I don't know the size of the jewel that came out, as it was shattered.  I did use a seitz jeweling kit.  The stump I used did produce perpendicular planes between reamer and bridge.  The hole was by visual accounts, perpendicular and very clean inside.  There were no impediments to the bridge sitting flat on the stump.  It was a tapered reamer.  The shank is a few thou larger than the business end, and the taper ends in a circular, non-cutting portion of the tool that mic's out to .229mm with the JKA tool.  The jewel measured exactly .230, purchased from seitz for this project.  I made the hole while waiting for the jewel to arrive.  Perhaps the first mistake.
If I had to guess, the original jewel was perhaps .180mm?  As said above, it would have been wise in retrospect to open a bit, check, repeat.  Sneak up on it as it were.
It was not a 5-sided reamer, I'm not familiar with the names, but the reamer's cut-out was half the diameter of the shank and progresses to immediately below where the tool is dead on .229mm.
The seitz kit I have doesn't have hole-closing reamers, but the staking set I have, includes stakes to peen/form the rivet (rounded and open, with the business end round like a doughnut) on the balance staff before flattening out the rivet with the flat open hole stake.  I'll use the former to attempt to open close the hole a bit.  I'll see if I can rectify it that way.
It was a learning experience.  This was an inexpensive orphaned movement.  If I can't close the hole, I think I'll buy another jewel significantly smaller, I do have a lathe, and see if I can turn a shouldered bush and use that.
I certainly appreciate all the positive feedback as usual.
Edited by SparkyLB
Do you mean a pin gauge set? Myeah, I've been looking for one, but no luck. I get by with shallow tapers and ad-hoc gauges, which is not as nice indeed..
   yes tool catalog.    you can use spade or some times twist drills.   it's nice have a set of those  anyway.  if  you had a lathe;  you could make " go - no go "  gages.   cheers  vin
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
