Riveting Stake
Don
I could have used one like this the other day when I was trying to insert a barrel arbor.
There's no way I'm paying $40 for one though. I got to thinking I could make one myself with some brass bar and my drill press. Is brass to soft for this purpose? Also, can anyone with a Bergeon 1902 give me the approximate size?
Thanks,
Don
Brass would almost certainly be a bit soft if you were going to actually use it for rivetting. However, for tasks such as installing barrel arbors I don't think it would be a problem.
I have a number of these rivetting stakes (including one that somebody made out of brass) that I have picked up in job lots of stuff over the years and they are very useful to have around. I have one which on the face of it looks like the one in your pic but I don't know if mine is a Bergeon 1902 or not. It's certainly the same arrangement and number of holes. Dimensions are 50.2mm x 14.9mm for the top surface and 5.9mm thick. It has a cross section like a fat "T" with the vertical being 10.5mm thick and the horizontal being 1.8mm thick. The biggest hole is approx 2.5mm diameter, and the smallest is approx 0.25mm Diameter.
Hope this helps.
The non-bergeon ones are much cheaper and do the job just fine. Why go to all the effort when they are so cheap.
E.G. http://www.ebay.com/itm/small-rivetting-stake-block-/281074274283?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item4171550feb
Or: http://www.ebay.co.uk/itm/NEW-Watch-Tools-Rivetting-Stakes-Set-of-Three-Pcs-/361188193705?pt=LH_DefaultDomain_0&hash=item54187e75a9
Mine is not Bergeon and I have had it since my apprentice days :)
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
