mesh netting
CaptCalvin
It did. But the green Depression glass as well as pattern didnt allow me to observe the clarity of the liquids so I switched them out for clear semi-square jars. They are still square but with corners significantly rounded compared to the originals.
Edited by CaptCalvin
    • Hello and welcome from Leeds.
