reducing dust
AP1875
Does anyone have a good solution for keeping their working area dust free? I am constantly cleaning down my bench due to dust, after a few hours there is a layer of dust that needs removing. The room i work in is about 5 meters by 2, carpet flooring and no windows. I was thinking about an air purifier
https://www.amazon.co.uk/Philips-AC2889-60-Connected-Anti-Allergen/dp/B07NPCHP1D/ref=sr_1_7?crid=RWDNH01CAQKY&keywords=air%2Bpurifier%2Bhome&qid=1581719264&sprefix=air%2Bp%2Caps%2C159&sr=8-7&th=1
does anyone use one of these or have another suggestion?
The first thing that came to my mind was a small, portable spray paint booth. I got one of these for my son that builds Gundam models. It's a bit noisy, but it does the job.
https://www.amazon.com/AW-Portable-Airbrush-Lighting-Painting/dp/B01EA3YBDO/ref=sr_1_10?keywords=airbrush+paint+booth&qid=1581724900&sr=8-10
Nice idea but It's not really practical for watch making, not enough space for your arms
