Need Advice on Removing Endstones
Lawren5
I'm working on an Elgin pocket watch and cannot remove the endstones on either the main plate or the balance cock. All other jewel settings of this type have just fallen loose upon removal of the two screws. However, in this watch, it's like they were press fitted in as I'm unable to even pry them out. Would appreciate any suggestions you may have.
Edited by Lawren5
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
