Show us your blue dial watches.
FLwatchguy73
Powder blue dial (which doesn't really show in these pictures) with light blue lettering, so it kind of qualifies as a Blue dialled Timex.
Circa 1964, and manufactured in Dundee. I must admit the mystery dial above puts this one in the shade. I don't suppose you would consider a swap? No? Thought not.
There are several versions of "Timex Cinderella", and later versions have a picture of the Disney character on the dial.
Omnia BG866 based late seventies pin lever with the ubiquitous for the time, offset crown.
I posted this recently on the Watch of Today thread. Of the three, it is far and away the winner, despite the pitting on the plating.
Edited by AndyHull
7 hours ago, JohnD said:
Bugger that's another one I'm going to have to look out for!:unsure:
That's the mistake I made by looking back from the beginning of the WOTD thread. No joke, I bought 5 watches I fell in love with there!:P sometimes I like to be original, but when a watch is cool, it's cool, even if I'm not the only one with it.
1 hour ago, GomBoo said:
No... It was a gift from my favorite local Watch Finder.
Are you saying that one is on the block?
Bob
The one I posted is indeed listed for sale. You can find it over on the bay.  But, did you know the one you show is not original.  the case should be gold toned.  The chromed case was used on the one I show and another with a multi color dial and white hands.  If I recall correctly the case style is a homage to an Omega that was also marketed in the early 70's just as these were.
  The movement stamped 'Britain', I've been looking for a while and I have never seen another Black dial Marlin with the gold block indices. The silver case may be an over the pond thing, I'll ck the 'bay'
Thanks
GOM
    • Look carefully at the tube end?? It appears to me to have a fragment thread visible? Either that or a step just away from the end? I can imagine a chamfer, but a step seems odd - but I've never seen the tubes used on these.
    • This is a very valid point and a subtlety that I was unaware of until fairly recently, learning all the time, the video below explains this point well:
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
