Serviced eta 2824/2
I recently brought a genuine 2824 movement. Cleaned and serviced myself, and timed on the time graph. I think I did a good job? I'm open to advice and critique. The movement came with a rado rotor, so i thought i look for a rado dial. To my luck? I found one to fit the 2824/2. 1897621999_Screenshot_20200129-023517_SamsungNotes.thumb.jpg.9da9849e4cd8542a34a127afb69894fd.jpgI brought a genuine Rado dial from a private seller on ebay, which is a lovely dial. I noticed the original hour wheel it came with was a H2. When the dial was fitted? The hour wheel barely poked out of the dial. I had to purchase another HR wheel from a seller in Switzerland, H4 size. That's was perfect. Here some pics of the movement and the results from the time graph.
  • Thanks 2
Great timings, even after 24 hours! Great job there. I've found the 2824-2 to be one of those movements you can adjust close to COSC standards for a relatively small amount of money for what it is. Also they're a real joy to work on. I bet you found that too?
I would love to see it cased up when you do
Hi Jon, yes, it's a real joy to work on these 2824, I had a great time! This is why I have a gold and nickel 2824.
I will update with some pics once cased up. Thanks Jon!
7 hours ago, Nucejoe said:
Good tg readings :Bravo:
Rado has its own caliber designation engraved on some movements, Dose it on ETA 2824?
Do you have a case for it? Will you keep us posted?.
Thanks for pointing out! I've not noticed the rado engraving? I will have a good look for it?
I will update once cased up.
Thanks Nucejoe
Thanks Nucejoe
Traditionally, A higher grade movement than Oris for example is housed in some Rado. Some come with screw micro- regulator mounted on stud carrier which gives a better control over regulating. I wonder if these good timings you got are for some part at least due to higher grade of the movement,  Also lets you approach  COSC standards. Someone may shed some light on this.
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
