Serviced eta 2824/2
I recently brought a genuine 2824 movement. Cleaned and serviced myself, and timed on the time graph. I think I did a good job? I'm open to advice and critique. The movement came with a rado rotor, so i thought i look for a rado dial. To my luck? I found one to fit the 2824/2. 1897621999_Screenshot_20200129-023517_SamsungNotes.thumb.jpg.9da9849e4cd8542a34a127afb69894fd.jpgI brought a genuine Rado dial from a private seller on ebay, which is a lovely dial. I noticed the original hour wheel it came with was a H2. When the dial was fitted? The hour wheel barely poked out of the dial. I had to purchase another HR wheel from a seller in Switzerland, H4 size. That's was perfect. Here some pics of the movement and the results from the time graph.
  • Thanks 2
Great timings, even after 24 hours! Great job there. I've found the 2824-2 to be one of those movements you can adjust close to COSC standards for a relatively small amount of money for what it is. Also they're a real joy to work on. I bet you found that too?
I would love to see it cased up when you do
Hi Jon, yes, it's a real joy to work on these 2824, I had a great time! This is why I have a gold and nickel 2824.
I will update with some pics once cased up. Thanks Jon!
7 hours ago, Nucejoe said:
Good tg readings :Bravo:
Rado has its own caliber designation engraved on some movements, Dose it on ETA 2824?
Do you have a case for it? Will you keep us posted?.
Thanks for pointing out! I've not noticed the rado engraving? I will have a good look for it?
I will update once cased up.
Thanks Nucejoe
Thanks Nucejoe
Traditionally, A higher grade movement than Oris for example is housed in some Rado. Some come with screw micro- regulator mounted on stud carrier which gives a better control over regulating. I wonder if these good timings you got are for some part at least due to higher grade of the movement,  Also lets you approach  COSC standards. Someone may shed some light on this.
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
