Seiko 7009-899A glass replacement
Evening all, hoping for yet more help with my increasing pile of unfinished Seiko 7009s!
I bought an eBay watch a week or so ago, received in the post yesterday.  After removing the movement for a service, the glass fell out of the case, complete with what appears to be an undersized gasket and flat ring.
I'm now trying to work out what to order to assemble the parts, and what I need to replace. The depth of the recess in the case is 1.8mm, the glass is 1mm thick, the flat ring is 0.8mm, the gasket is too small for the glass.
My instinct is that the flat ring goes in first, then a proper sized gasket, and then the glass.  But I'm not sure whether this arrangement would work, in particular whether it is possible to press a glass into a gasket with a rubber seal flexing as I do so!
Any advice would be much appreciated, thanks.
The watch is a Mumbay special as the funny lettering on the dial shows. Don't bother too much trying to make sense of how parts should fit together because the sellers puts together things just to ship it out. If the crystal is not the correct size for the case you will need another one. The flat gasket below it may not even be needed, also there are L crystal gaskets which raises the crystal if needed. It's all about measuring to fix it but I would suggest that you look for a more genuine Seiko for a next purchase.
Hi If you have a pile of unfinished 7009's check to see if amongst them you have a genuine one check out the case fittings.  The bombay specials are just cobbled to gether to sell and may well be from a collection of case and movement parts.  I have a couple of 7009's so I will have a look when time permits.      Cheers
Hi   I had a look at them and both cases are different one has a flat crystal and from what I can see without dismantling is there is a flat gasket at the bottom where the crystal sits and the crystal its self is pressed into another gasket, so both gaskets need to be snug fitting to achieve water resistance.
The other one has and acrylic high dome and that is just a compression fit using the glass lifter to squeeze the acrylic to allow it to locate its seating on the case.  You may find reading the attached guide will be of some help in understanding  its construction.      Cheers
03. Casing Guide seiko.pdf
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
