Re.Illustrated Manuel of American Watch Movements
Hi, I am trying to source an affordable copy or pdf of the: Illustrated Manuel of American Watch Movements. by the F.J. Swigart Co.
I have found one or two but the prices are very high indeed. any ideas or suggestions of possible sources would be welcome.
Many Thanks
1 hour ago, jdm said:
USD 45 would be too expensive? https://www.abebooks.com/servlet/BookDetailsPL?bi=30411952989
BTW we have a dedicated section where is considered polite for new members to introduce themselves.
He signs himself MIke with location Norfolk. For most people that is sufficient introduction. I wonder how many are discouraged by being lightly tapped over the knuckles by jdm becaus they do not give their hair color and shoe size?
Duly noting your knuckle tap, Watcher from the UK. Perhaps you may want to extend it to out Host Mark Lovick, as he wrote:
New to the community? We like to know who we are chatting with :)
So why not introduce yourself here first!
  • Similar Content
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
