Rolex Submariner Case Opening Issue
clockboy
Have problems opening my Rolex submariner case back. It has never been opened before so I think the issue is just very tight. Removed the bezel to clean and it was really,really dirty so I expect this is the issue with the back. I have been trying to open with a opener made by Huaxing but it will not budge and eventually the die slips. I don,t want to do any damage but I don,t know if the die is just a bad fit as it is not a Bergeon or if I need a more substantial opener any one with advise will be most appreciated.
I have one of these myself and it's served me well. Have you tried gripping the case across the points of the lugs in fibre vice soft jaws to allow you to exert maximum downward pressure while applying torque? I had to do that with a Tudor Oyster that didn't want to open.
Thanks Geo, to get a really good purchase I removed the bezel inserted the watch into a watch case holder. However I put downward pressure before twisting with a lot of pressure (more than I like) but no good and eventually the die slips. I was just wondering if the bergeon die is a tighter fit or I need different style of remover. The Bezel was really tight even with a Bezel remover and the dirt under it was substantial so I guess this is the issue.
I just do not like forcing for fear of damage.
Edited by clockboy
I also have a set of the cloned Bergeon dies and some are OK and some slip - even when I use them in the bergeon bench case opener.
I purchased some Horotec dies (which also fit the Bergeon case opener by the way) and never had a problem since.
Do you have a glass lifter (the type with all the prongs)? If so, you can try tightening it round the back and turn. Sometimes works.
Thanks Mark, I have a glass lifter (prong type)& will give that a try. If no good I will look at Horotec dies perhaps. I presume I can get them in Cousins. I just have a feeling to shift its going to require a pro type tool.
Could be time for the supa glue and a 19mm nut!!.. :startle: ....its never failed me......then tighten back up with the die if you can. A few weeks back I did just that on my Breitling asI wasn't going to spend £50 for a die and it worked fine. I have the same set of dies you have and they worked fine on my Sub but it had been serviced before so not on as tight as I expected.
Edited by ash145
Absolutely it will. That, and it's Bergeon (5700, my one) brother are extremely good tools. The good thing is you will get dies for Rolex, Panerai, Baume & Mercier and Breitling to fit. If you have the budget, its a no-brainer.
I'm sorry I'm late for this thread! (clockboy just pressed the button!) but the opener Geo recommends is excellent, (I just got one for Christmas) if it is the original LG. The down side is they only come with the Rolex dice! In any case, I also got a Witschi opener that accepts Horotec and Bergeon parts!
It is here: http://www.ofrei.com/page557.html#27092
Cheers,
Bob
I have a set exactly the same Chinese back opener set that Clockboy was using and it's worked very well with both my vintage Rolex and Tudor. The only case it wouldn't open so far was a Chinese copy Rolex.
Edited by Geo
New toy arrived added pic. Opening the rolex case with the Horotec was simple with no effort.
Conversation "whats that dear"  ------ "Oh just a tool for my watches" ---- "how much "  ,
"no nothing really, only a few quid dear "  :D
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
