Rolex Submariner Case Opening Issue
clockboy
Have problems opening my Rolex submariner case back. It has never been opened before so I think the issue is just very tight. Removed the bezel to clean and it was really,really dirty so I expect this is the issue with the back. I have been trying to open with a opener made by Huaxing but it will not budge and eventually the die slips. I don,t want to do any damage but I don,t know if the die is just a bad fit as it is not a Bergeon or if I need a more substantial opener any one with advise will be most appreciated.
I have one of these myself and it's served me well. Have you tried gripping the case across the points of the lugs in fibre vice soft jaws to allow you to exert maximum downward pressure while applying torque? I had to do that with a Tudor Oyster that didn't want to open.
Thanks Geo, to get a really good purchase I removed the bezel inserted the watch into a watch case holder. However I put downward pressure before twisting with a lot of pressure (more than I like) but no good and eventually the die slips. I was just wondering if the bergeon die is a tighter fit or I need different style of remover. The Bezel was really tight even with a Bezel remover and the dirt under it was substantial so I guess this is the issue.
I just do not like forcing for fear of damage.
Edited by clockboy
I also have a set of the cloned Bergeon dies and some are OK and some slip - even when I use them in the bergeon bench case opener.
I purchased some Horotec dies (which also fit the Bergeon case opener by the way) and never had a problem since.
Do you have a glass lifter (the type with all the prongs)? If so, you can try tightening it round the back and turn. Sometimes works.
Thanks Mark, I have a glass lifter (prong type)& will give that a try. If no good I will look at Horotec dies perhaps. I presume I can get them in Cousins. I just have a feeling to shift its going to require a pro type tool.
Could be time for the supa glue and a 19mm nut!!.. :startle: ....its never failed me......then tighten back up with the die if you can. A few weeks back I did just that on my Breitling asI wasn't going to spend £50 for a die and it worked fine. I have the same set of dies you have and they worked fine on my Sub but it had been serviced before so not on as tight as I expected.
Edited by ash145
Absolutely it will. That, and it's Bergeon (5700, my one) brother are extremely good tools. The good thing is you will get dies for Rolex, Panerai, Baume & Mercier and Breitling to fit. If you have the budget, its a no-brainer.
I'm sorry I'm late for this thread! (clockboy just pressed the button!) but the opener Geo recommends is excellent, (I just got one for Christmas) if it is the original LG. The down side is they only come with the Rolex dice! In any case, I also got a Witschi opener that accepts Horotec and Bergeon parts!
It is here: http://www.ofrei.com/page557.html#27092
Cheers,
Bob
I have a set exactly the same Chinese back opener set that Clockboy was using and it's worked very well with both my vintage Rolex and Tudor. The only case it wouldn't open so far was a Chinese copy Rolex.
Edited by Geo
New toy arrived added pic. Opening the rolex case with the Horotec was simple with no effort.
Conversation "whats that dear"  ------ "Oh just a tool for my watches" ---- "how much "  ,
"no nothing really, only a few quid dear "  :D
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
