Bulova Automatic
Was repairing a bulova diver from the 60ies I think and the rotor was loose and the watch wouldn’t run.5f2b9c31254729c796e4895f06c254dc.jpg
I decided to disassemble it a bit.69eccf89383c6859ddb3c2d261c4e094.jpg27d7ef21bf4ba5fd888be1dfb38afa78.jpgbb0633adfecfa2cc8dbc432c49cff93a.jpg15110451afbaf34a16dccf68d1e5f8f2.jpg
I removed the second plate and when I flipped it over I found that there were two screws loose on a sub-plate the pushes up on the arbor / pivot that the rotor center hole slides over. Once I tightened the two screws the arbor pushed up. 2ba6207ecedde574579c441f1abe7fe6.jpgfae8e142673d4734c180b4d172fec2f7.jpg9f61d3f244f634a3a061c705badde16a.jpg
I reassembled the watch and it worked perfectly. Tomorrow I clean and polish the case as well.
adee8ef5e3aac60241785971f2cde198.jpg6acc586298e00371ceee473ef49a2d20.jpg7f92a4de65a122b94120d40a828142fc.jpg
I got a Buren with loose rotor, pretty sure would have to bush the rotor, axle needs work too. Would go machining or spend the rest of my life searching for replacement parts. TIA.
Edited by Nucejoe
Would you go machine
I would sludge hammer the watch or spent the equivalent of 1000 hours trying to fix it
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
    • I bought this box of jewels a few years ago and noticed that the glass containers are divided into two sections. In the first section, the containers have a label with red text colour and always start with the letter B. In the second section, the text on the label is black and lacks the letter B. There seem to be roughly the same number of containers in both sections, and each section has the same sizes of jewels. The only difference is that the jewels in the B section with red text have a slightly rounded, convex underside. My question is what are these rounded jewels for and if I can use them instead of the jewels with a flat bottom if a certain size is missing?
