amplitude
Hi all ,an old watchmaker friend of mine he is 76 and still goes to work as a watchmaker everyday . Imagine his knowledge .Anyway on with the topic . As you all know sometimes when you service a watch it doesn't matter what you do the amplitude would be nice another 5 or 10 degrees higher .Peter (that's his name ) told me to get an old piece of ladies watch mainspring and cut it about 2 inches long and wire it to a piece of pegwood leaving an inch hanging past the end .Get a hold of the pallet fork with a holder of some sort ,tweezers will do if your steady enough and burnish inside of the folk where the impulse jewel makes contact . This works amazingly as it polishes the inside and gives an uninterrupted smooth passing of the impulse jewel .Takes a bit of time  but it works . I wanted to make videos of him doing some great stuff and upload but he won't let me Anyway give it a shot .:cigar:
  • Like 6
Sounds like a good trick
This does make me wonder about pallet refinements on some watch calibers.
On fancier JLC calibers, they use a common pallet which is interchangeable with the pallets used in the same family of movements. But they finely polish and chamfer the edges to remove material where it is not needed. I always thought that this was purely to lighten the pallet fork to reduce inertia in the escapement and to improve aesthetics. But now I’m wondering if they did provide an improved surface inside the horns. I’m currently working on a Cal 488 with modified pallet, so will compare under a microscope....
I work on a lot of old JLC movements, tending toward the smaller and thinner but also up to small clock size. They tend to have a very good finish inside the fork slot, even if the beveling on the non-functional areas is rudimentary. However, it's not uncommon to see (with microscope) a faint or even significant "dent" where the roller jewel smacks the slot, and touching this up does usually help. Seems worse with the old triangular roller jewels.
Mainspring as a burnishing tool is good technique. Even with thin spring though there can be very little clearance for the spring/burnisher with the guard pin so be careful!
Some of those old JLCs also have very high lift angles, like 56, 58, even 60.
If the lift angle is great, then it implies that the escapement is possibly less “detached” or has a larger amount of drop. Or, more broadly that the balance spends a longer time interfacing with the pallet fork during a cycle.
It’s hard to speculate why it may have been designed in a particular way, but I’d welcome hearing any comments.
In terms of the 1948 dated cal 488s which I’ve worked on, they achieve ruler-flat rate with negligible positional variation when running well. I believe that the balances would have been specially adjusted for this caliber. Otherwise they look the same as what you’d find on a Cal 450.
I’ll need to pay more attention to the condition of the slot by the sounds of things.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
