6498 Hairspring - Can It Be Saved?
BlakeL
I got lucky and was able to find somebody locally selling a #18 K&D set.  It's about an hour and a half away but is a very good price and doesn't look to be missing very many parts.  The picture is not great but it does look as if some of the parts have rust but hopefully will clean up fine.  I'll be picking it up next Sunday.
  • 5 weeks later...
I got back to working on the 6498 last night.  Fixing hairsprings is so delicate I find myself correcting the bends/twists then right after making it much worse. I was able to fix one of the worst twists but now I have a very slight downward bend towards the end that you can't really see and at some point when trying to grab the spring I bent the inner bronze ring so that if I mount it does not lay perpendicular.  It might have been like this from the beginning but I have a feeling it was me.  Any suggestions?
Edited by BlakeL
I struggle with hairsprings although better than I was. I found the last time I wanted to bend up a touch I put the hairspring on a staking tool & put it where I wanted to bend over a hole and pushed VERY GENTLY with some Dumont 5 tweezers and it worked.
Edited by clockboy
Good idea, I might have to try that since I have a staking set now.  It should be pretty easy to finish off the end but that bend in the inner ring scares me but I'll have to try since a replacement won't be cheap if I can even find one.
Like I said me and hairsprings just don,t get on.  But this method worked but you have to be very gentle with it.
I see a vid where a guy was making a hairspring overcoil and he pushed the hairspring into a tube that he had made which is the same principle.
Edited by clockboy
I spent some more time with this over the weekend and I've given up for now to save my sanity. I'll keep this movement for parts and come back to it later when I have some more experience and a better 10x loupe. I found another cheap 6498 pocket watch on eBay for around $50 that is working. It does have some rust on the ratchet wheel but i can swap that out.
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
