Greetings
I was told I should introduce myself so hello everyone. My name is Jeff and I am from North Carolina, USA. I don't have much of a watch collection, mostly old 18s Elgin pocket watches I tinker around with; A couple of Elgin automatics (with the American movements) and a Gruen Precision autowind that needs a lot of work (I got it just to look at the calendar function).
2 hours ago, Eflitzer said:
Welcome...very familiar with your neck of the woods; used to work in Edenton, NC, retired now on Scottsdale AZ
Edenton is still a nice place.. after I escaped from New York, I ended up here.I Didn't  have to apply for asylum and they take the same money.The language is slightly different , but comprehensible. You couldn't chase me out of here with a stick of dynamite.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
