6119 spec sheets
Hello everyone!  I’m trying to figure out if parts from a 6119 will be compatible with a 6138 and to that end I’m looking for a spec sheet for the 6119. I’ve already received the 6138 sheets courtesy of you fine folks here, wondering if the other is available.
Also, is there a specific area of the forum I should be looking in for the specs?  I haven’t seen one in my ramblings.
20 minutes ago, watchweasol said:
Hi   I think this is a better sheet than the SCWF one its clearer.
One nice feature of this forum software is that we can re-use attachments we had included before, saving us more uploads. From the "insert other media" chose "existing attachment". Type in few letters that identify it, and you will be presented with the relevant matches. Select one or more, then the green insert button.
Edited by jdm
11 minutes ago, watchweasol said:
Thats fair enough jdm   I shall refrain from posting anything in future.  I looked at the SCWF sheet and it wan't well copied so I attached the other sheet.
Maybe you got my intentions wrong. I merely indicated how one can do faster sharing one's own existing attachments. Could be useful to you as a frequent provider of this type of information, which is always appreciated.
Edited by jdm
Hi   I do it this way because all the files are located on the computer as PDFs having been gathered over many years and stored . I also have access to a collection on printed material and a lot of books collected over a long time. I have been repairing clocks and watches for almost 60 years as a hobby. I joined this forum ( the friendly forum) to help others when required, Look for no street cred or anything else just to help those not so clued up whenever I can ,.
Please keep on the good work W W.  Your posts have been helpful.
2 minutes ago, LonglineOjoe said:
Thanks for a all the help once again!!  I feel as if my posts are always stirring a hornets nest though. I hope it’s just friendly banter :(
No wasps and no banter, I have just been misunderstood while suggesting shortcuts to posting helps. Good luck with your repair!
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
