Sportsmatic Weekdater loose crown
Hi, new to repairing, just getting my feet wet, so be prepared for me to use incorrect language, and have things explained like I'm 5 :)
A couple years ago, I purchased a Seiko Sportsmatic Weekdater, cal. 6619-7050.
Soon after purchase, the crown detached from the stem, and I took it in to local watchmaker for repair. It was returned in apparently good shape, but actually the problem still exists.
I'd like to learn how to fix the problem, and hopefully bring this watch back to my wrist.
It appears that the crown screws onto the stem, but that is as far as I have got.
Any assistance would be welcomed. I did find a service manual elsewhere, but I'm a bit lost as it's my first.
Seiko Sportmatic 6619A.pdf
Just now, Trevelyan said:
I did notice the movement seems a bit loose in the case. Can either of you tell if it's missing anything from the pics, or do you need a better/different pic to tell?
Once screwed in the caseback presses on the mov't ring, so nothing to worry.
4 hours ago, watchweasol said:
Hi as jdm says use loctite or other thread locking cement. do not put too much on.
   Loctite is # 1.    the 3 basic strengths have been around for years.   if you want to remove it,   250 degres F.  will losen it.  vin
   i forgot to mention;   both surfaces need to be free of oil.   alcohol or acetone.   vin
  • Similar Content
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
