Need opinion
6 hours ago, jdrichard said:
Is this a good diver watch?
What do you mean? It's a vintage piece, you can find the asking price of similar ones on chrono24.
BTW, you have posted in the projects section that is to show others how things are done, if you want just show a watch or discuss we have both a watch collection and and a general watch discussion section.
Edited by jdm
Probably not with that gasket :wacko:
But if sealed to original factory spec then yes, it should be good for a static pressure equivalent to a depth of 666ft of water.
However, even with new replacement gaskets (back and crown) and a new crystal, you may struggle get it to achieve original spec. It's a 54 year old and over time it's possible that the surface condition of the sealing surfaces of the back and case, the crystal seat, and the crown could have deteriorated, even if only very slightly, making the original spec difficult to realize. It all depends on how those surfaces have fared over the last half century.
You can really only make that judgement after a pressure test.
On the other hand, as a desk diver it's brilliant :D
On the other hand, as a desk diver it's brilliant [emoji3]
Thanks. It is not working, so first I need to strip it down an see where the issue (s) are. I do agree that a desk diver is where it belongs. I did get another diver yesterday. Bostok Amphibian655377b3f9e9d3a15094c3c9fb75dae4.jpg
Sent from my GT-N5110 using Tapatalk
On 1/31/2020 at 2:20 PM, watchweasol said:
Hi JD  looks a decent watch plenty if information available on the 11ALAC,  suitably sealed and pressure tested I would wear it for sure.
It is a quality movement, what I like about it especially, is its bush bearing rotor.
Some come with permanently sealed barrels.
In my book its design is superior to ETA, more like zenith movements.
A lot of history in this company and the watches are built like tanks. I now have two.
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
    • It's pronounced "bombay" like the city.  French for bomb is, 😄, bombe, pronounced the same as in English. Bombé, bombe.
    • That's a really good idea! I have a 3d printer, I think I'll design something that I can clip on to the edge of my desk to do the same. Thanks for the idea.
    • I looked up bombè, domed in French.  It's pronunciation is bomb, does a bomb (explosive device) get It's name from bombè? I know we're going off subject but it's interesting.
    • Okay, I checked with the fine folks at the McCaw Company, and they agree it's the correct crystal, and they have one in stock, so with that sorted time to get onto assembly. Starting by getting the spring into the barrel, which was a bit harrowing. It took me several tries to get it hooked onto my worn old winder arbor, but I did find a new use for the micrometer stand I just purchased. Carefully dabbed some Kluber P125 braking grease to the left of the divots around the barrel, and a little HP1300 on the floor of the barrel before popping it in--in case you haven't seen it, this is a great illustration I found somewhere on this site. You're not the boss of me, Bulova.   2172_Bulova 11AOAC 11AOACD 11AOACB.pdf Bulova_11 AOAC, D, B(1).pdf I got the train back in and it didn't seem as free as I'd like. Looks like the driving wheel with cannon pinion has zero end shake. That could explain the low amplitutde I started with. Now if you were me, would you push on the plate jewel or the bridge jewel? I've attached some extra pictures in case anyone sees something else I'm doing wrong here.
