Look at this beauty "William Goffe"
clockboy
I have been asked to look this beauty. It is heavy and is real quality and the name on the dial is (I think) is William Goffe. On initial inspection it looks like the cord /gut has broken from one of the barrels. Also to open the front is via a key which is missing,
I will investigate in a few weeks as I am away on a short break. I must say I can't wait to delve.
IMG_4911.thumb.jpg.d8d9e40173e72f1882777cfcdad8220a.jpgIMG_4915.thumb.jpg.76f9f5369973beaa9138d9f1db5c2b69.jpg
1 hour ago, clockboy said:
William Goffe
"William Goffe, Watchmaker and Chronometer maker to his Majesty’s Packets, is listed in as working at The Moor, Falmouth c. 1800 in Cornish Clocks and Clockmakers [H. Miles Brown]. He is listed as a London maker in Baillie’s Watchmakers and Clockmakers of the World. "
Source -> https://lapada.org/art-and-antiques/domestic-regulator-longcase-clock-by-goffe-falmouth/
Keep us posted with your progress.
I do like how the pattern on the back plate has been continued on the brackets to hold it in the clock. I've not seen that before.
I do like the hands although it looks like the minute hand has been twisted slightly, but I would think long and hard before trying to straighten it.
I would date that at around the early 1800’s, with takes it into the regency period of clocks.  It is an 8 day English Fusee Bracket clock. The pattern on the back plate is what you would expect with a clock of that date. The early ones the back plate would have been completely engraved as to would the fixing brackets and pendulum bob. Painted enamel dial with convex glass. I expect it has rack striking striking which is on a bell.
Do I see a cut out at the base of the clock for the pendulum? If so then this is a marriage.
The movement also seems to hovering in mid air above the seat board, is this correct for a clock of this period or could that also be a sign its a marriage ?
Yes there is a cut out for the pendulum. The customer did say it was an early 1800,s clock.
Yes you are right. It should be fitted to that seat board. More signs of a marriage.
Just an update of the William Goffe clock. The movement has the maker as "Handley & Moore" and after some research I found the exact movement for sale @ approx £4k. However this movement is a wreck see pics. All screws are really badly bruised and the clock has numerous bodges from poor soldering to an extremely worn barrel arbour and the hour hand was screwed on.  The mainspring is broken and the one fitted is not the correct width (too narrow) and so it looks like it was fitted high in the barrel but as a result has been binding on the cord hence it breaking. This is now a major repair so it is up to the customer to give me the go ahead before I proceed any further.
UPDATE. Before polishing the bruised screws etc I thought I would assemble just make sure all was well as this is my first fusee clock. The technic of winding the fusee wire was challenge but after a few fiddles all is fine. However (there is always a however!!!!) it only strikes the hours NO half hour and I guess I have something put back wrong or it has no half hour function. But, there is a lever that I just don't know what its function is, maybe it the half hour function. see pic.
19 minutes ago, Tmuir said:
Its not the chime / silent leaver is it?
Although it doesn't look like it engages with anything in that position
The strike/silent lever when engaged pushes on the the end of the lifting arm arbour which enables the pin on the minute wheel to engage with it, when the strike/silent lever is disengaged the arbour is pushed forward by a large spring on the back plate of the clock preventing the arm engaging with the minute wheel pin and stopping the clock from striking.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
