Meantime Screws
I am working on a beautiful 21 Jewel Gold Splashed Elgin movement and it is running way to fast, past the adjustment leaver. So the question is, do I just unscrew the meantime screws on the balance (2 Screws, equal turns) or do I also do the Quarter Screws?e740261656b2b99a1d9fc7536157f6bf.plist9329a5300ea0e53bf5b7634d519f5f37.jpg048bbf91cb7fe87e120e0ac4f3d6d373.jpg
The balance is in beat after I adjusted the collet (approx .5 ms).
The ones on the arms are know as 'Mean Time Arm screws' and the ones in the middle are 'Meantime Rim Screws'.
I've never had to do this but when you think about it you must adjust all 4 equally or the balance will go out of poise.
Henry Fried's book says half a turn can give or take out to a minute a day.
I've just noticed in the photos it looks like the mean time screws are all screwed in flush with the rim of the balance, usually they are unscrewed slightly from factory to regulate the watch, the fact they are all screwed in makes me think someone has fiddled with it.
I only see 2 meantime screws at the arms, no other "adjustable" screws. If you have 4 you very much can move them in pairs, no need to touch all 4. Start with quarter turns, and see what the result is. If you get more than maybe 3 turns out from the rim you should try adding timing washers (in pairs, opposing screws of course).
I agree. The watch was running way too fast. I have turned all 4 screws and perhaps only needed to turn the Meantime Screws. I have around 2 turns on the meantime and 1 turn on the rim screws. The rim screws feel a bit loose and I may screw them back in and just work with the Meantime screws.
Very good advice. I do have timing washers and may add a set to the meantime screws to set the regulator arm in the middle.
I don't see any adjustable screws apart from the 2 at the arms, so it's normal they'd feel loose if you did others. Meantime screws will always have longer threads than the rest.
I think i "screwed" up. I screwed back the quarter screws as well and I don't think they are quarter screws. Plan B is to screw them back in and turn out the meantime screws one or two more turns...add washers if I have more than 3 turns as recommended and see where I get. BTW, I'm doing this with the balance in place but hold it carefully with tweezers. Any issue there?
Sent from my GT-N5110 using Tapatalk
Well you're risking the pivots if you end up putting too much pressure, but it is done that way by many.
I am being very careful. The watch has a 550 deg swing, amazing amplitude (270). So after 2 days the watch stopped. The non-quarter screw that I accidentally turned, thinking it was a timing screw as well, turned out on it’s own and ended up touching the balance cock. So I tightened the screw and it’s brother and turned the Meantime Screws another 2 turns. Watch is still at +60 seconds a day. When I get home I will add timing washers to the meantime screws at the arms of the balance and get the darn thing timed.
No, washers only go on the normal screws, and get tightened down.
Quarter screw and meantime screw means the same thing, I think the Brits say "quarter" more where Yanks say meantime. Some watches have 4, at 90 degree spacing (thus "quarter screw"), some just 2. When there are just 2 they are typically at the arms like in your watch. They are just for getting the balance close to a general (mean) time, with the regulator in the middle of its course. It's very much discouraged to use them for correcting poise error, although you can if it's just a small adjustment.
So you have two meantime or quarter screws, the rest are just balance screws. The meantime screws will always have a longer thread, and show some resistance to turning even when not screwed down- they will in fact generally not be screwed right down to the rim. The regular balance screws will always be a free fit on the thread, and always need to be screwed down tight. Timing washers are used on these screws if needed.
Balance screw holders are very nice to have, really essential for small balance screws, when dealing with adding washers. They are essentially little pinvices with sized tips, Bergeon sells them.
So the timing washers would be placed on the two opposing screws that are 90 deg from the balance arms. Is this correct? By the way, thanks for the advice. And is there a book that explains the placement of timing screws . I do have the tools needed to work with the balance screws:)
      do you a screw driver that will hold that little "cheese head" screw?     vin
There are much more elaborate sets of timing washers, for a given size of watch there are usually 3-6 different washers possible. You can see the carton boxes are marked on the lid, the wooden Bergeon set inside, the Bergeon gives the watch size and hole size in the washer. Of course there can be balances with different inertia in a given ligne size so the "seconds per day" is an approximation.
I'm sure with your set you'll find some that get your watch on track.
  • 1 year later...
I know this is an old thread, but I wanted to remark that I am glad I found it.  I have a 1925 Waltham grade #210 which is running very fast, but a steady and consistent gain of 48 minutes per day.
Originally it was not running well because it had a cracked upper cap jewel and an upper pivot that had a bit nipped off the top.  I replaced the jewel and got a like-new balance complete, and poised it.
I made sure to get it in beat.  And it ran super fast, beyond regulating.  I examined the hairspring, and it wasn't touching or bumping anything, and coils were evenly spaced and breathing well. Still, I cleaned the balance and demagnetized everything.  Still too fast.  I adjusted the meantime screws, as explained in this post, and saw some minor reduction, but I think I will also need to add timing washers. I have a few that are the correct size.  The mainspring looks to be original but I think I will measure it again just in case.
Otherwise, it runs so smooth and so well.  Just hoping I can reign her in.
Addendum: the picture of the movement is an earlier one.  Currently, the movement is the cleanest it has ever been and the regulator is all the way to the slow side.
This was what we Americans would label a "barn find", a ratty-looking but easily restorable piece going for cheap.  I paid $20 US.
one of the problems with finding a discussion like this is that I perceive each watch to be a unique problem and you really should post your own question.
a problem with a like new balance complete is we do not know its history? Did somebody mix-and-match a balance wheel from one watch with the hairspring from another visually they look right but are they right?
Then before you poised did you true the balance wheel? In other words is the balance wheel perfectly round? The reason I ask is bimetallic balance wheels are easy to bend the arms in and if the arms are bent in by just the tiniest amount the watch runs fast. So before you can poise you do have to make sure the balance wheel is round.
typically in a discussion groups like this if somebody had a watch now running superfast in particular American pocket watch I would tell them to look at their balance screws. A lot of times one of the screws will fall out and then you run insanely fast. But as you did the poising that wouldn't be an issue.
then timing washers are not to be used for what you're thinking of using them for. Notice if you look at the images up above the rated as minutes per 24 hours. Also you're only supposed to have one washer under a screw so if you do the math you need a heck of a lot of washers and I doubt you have enough screws.
you'll notice I attached some images and a PDF. One of the images shows Waltham timing or poising screws. As it is possible to change the hairspring the only way he could bring the watch into time would be would have to build the change the screws. So typically any time hairsprings can be changed there are associated screws to go with it. You're running way too fast for any normal method of slowing it down you need heavier screws. Fortunately as you put a balance complete on you have an old balance wheel but you're not using so you can see if you can find suitable screws there. One of things you want to look for is if somebody got insane with undercutting the screw heads when they were doing that poising just putting screws on that haven't been undercut will help.
then the mainspring is not the source of the timing problem unless it's dramatically wrong. And I would give it was super super strong. But if it is the original mainspring and it looks set it will definitely be a running issue problem you won't get 24 hours a running time.
hamilton_tech_note_on_regulation.pdf
@JohnR725 thank you for the wealth of information on this.  I originally posted here in an effort to see if my problem was common enough to already have an answer.  Most do.  I do try to search the forum first before posting something which may be a rehash.  But this time, I must agree with you: to get answers specific to this watch, I will have to draft its own post soon.
To answer an earlier question, I did both true and poise.  It seems quite true and balanced.  BUT...I did not think to look for undercut screws at the time.  I will be doing that.  And I will spend some time reading over what you sent, and contemplating the physics of what's going on.  Thank you again sir.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
