watch strap fixings
Hi,
I've got this Lorus digital watch whose strap broke a year or so ago. On the plus side, that caused me to get into mechanical watches, and indeed fixing them. But I still like this watch, and would like to be able to wear it.
But here's the problem: i can't find a watch strap that I can fit onto it!  It doesn't use a spring bar, just has a steel rod that passes through a lug on the strap, then the case, then the strap again (see pics). But I can't find any kind of replacement - nothing that fits in the same way. Lorus doesn't do a replacement strap - i've emailed them and their parent company seiko, and I know the watch only cost 20 quid or something, but I don't want to chuck away a perfectly good watch, a watch that works well and I like, all because I can't get a strap.
Anyone know where I can find a strap that will work? I've tried ebay, amazon, cousins and one or two other watch parts places, but nothing.
Any ideas?
Have you tried this type of strap ? I don't know what they are called but they come in various shapes and sizes. I would imagine that the metallic rod comes out and can be replaced with such a strap and its springbar ? There are also bracelets like this as well. Not as common as the traditional ones but they exist. CousinsUK has such models, or at least had at some point.
Edited by Chopin
The pins are called screw end or screw head strap pin, prices start at £1.99. regular straps can be cut to fit.
Thanks all for your replies.
watchweasol - yes, i've been onto lorus/seiko, and even got a reply which was that they do not make or sell replacement straps for that watch. Bit annoying to be honest when the watch is actually really good for what it is.
I will look into  those other straps tho - thanks everyone.
     GOOD IDEA  !   vin
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
