remove case back
tomsch
It looks like a friction fit pop off back, with the seam around the center line, split across the stem. You will need to have a new single edged razor blade, preferably in a plastic holder to better handle it. Nothing thicker will do it, you would just bang it all up with a screwdriver bit or any other case back tool. Carefully push it into the gap between case back and main case then try angling the blade up to see if it will start the back coming off. You may need to do it in more than one spot to get it going. Don’t be dismayed if you break pieces off of the blade. Just throw it out and grab another one. Hope this helps. It’s just one of many methods that you will have to learn If you work on enough battery powered watches. Steve
Sent from my iPad using Tapatalk Pro
there is a slight opening in the center line opposite the stem, at 9 o'clock.  I was able to open that, but that line merely removes the movement, with the back still on it, from the crystal, which remains in the top case.  I think the part that has to be removed is the fine circle that is set in from the edge on the back of the watch.  Is that what you recommend using a razor on?
Take the top part of the case with crystal off and post some good clear close up pics of the bottom part of the case with the movement stuck in it.
thank you all for your helpful replies.  Here are pictures, responding to one of the replies, of what I'm dealing with.  separating at the midline removes the movement from the crystal.  The close up of the back shows the disk that has to be removed to access the battery.  There is no opening anywhere along that circle.  I was able to get Chopard to tell me, at least, that it is not a screw on.  Of course they recommend sending it to them for the battery replacement, which I'm sure will cost a couple hundred at least
Now it looks like you have one where the movement, dial and all is seated in that half of the case. If that is so, you would gently lift up the dial from the 9 area and while turning the crown slowly, see if it doesn’t come out. It will have what is called a split stem, where the stem comes apart via a slot in it. Look up split stems and you will see what I am referring to. Steve
Hi  Thank you for the pics Looking at the stem tube this looks like a front loader with a split stem. The stem is in two halves and clip into one an other.  As Gpsluvr mentioned look up split stems and you will see what we mean.  The idea is that you remove the half with the crown on and the movement should lift out. Removing the stem one needs to be carefull there are various methods to remove the stem but every one of them requires a straight pull. Again look up how to do it.
As already stated this looks like it may well be a split stem in which case a quick note of caution.....
If you use any thing to lever against the case to remove the outer part of the stem make sure you use something between the case and the lever to protect the case. It can be very easy to mar an otherwise good case if you don't, and as yours looks to be a solid gold case the risk is even higher.
i hate split stem cases like this, i would suggest to avoid issues like marring as Marc said, take it to a jeweler and ask them to just remove the movement and thats it, it will cost much less, and then you could do the battery replacement yourself and re-assembling would be much easier than dis assembling.
watchweasel, yes I'm having fun with it.  Polishing up the case while waiting for the $1.00 battery from Amazon.
Make: Chopard
Numbers on the back: 340677 and beneath that number, 4103
Inside the case back there are a number of stamps and etchings, including:
LUC (stamped) which Chopard says designates their highest quality in-house work, made only at two locations in Switzerland
750 (stamped) designating gold
this etched at 6:00 o'clock: "MS 10/09/19"
In the center - the Chopard logo image with balance scales beneath it and "750" stamped between the scales
beneath that, "TM 19735" etched.
I wish I could take a nice close of the inside of the case back but it's all to small for anything I have to take pics.
    lots of vintage watches  have the assembly that way with the mvt. fit into the case bottom.  usely a slip fit with a notch for the stem to come out (2 piece stem not rquired.  vin
 Yes iam familiar with those too, a lot of Waltham/Elgin’s from the late 20s and 30s have cases like that they are much easier to open up.
Hi Tomsch  The movement looks like an ETA which chopard used , On the outside rim near the coil there should be a number like 955 12 or somthing like can you post it that is the make and calibre of the movement.  Chopard are quite often compared to  Rolex so you have a quality piece there.   cheers.
    • @Murks the problem you have mate is most watch cases out there to buy are for Seiko NH3X, ETA 2824 and maybe Myota 8XXX movements, oh also the big ETA 6978/9 movements which the dials start around 28.5mm. You might find one on a Google search but I suspect your main chance will be buying cheap quartz ladies watches and hopefully find one of the right size and condition that is acceptable. 😞   Tom
    • The anchor pin should be perpendicular when the anchor is sat on a flat surface and if you post a close up picture of the backplate I will be able to tell you the correct torsion spring , running fast or slow is usually wrong Torsion spring. Here is a video from my YouTube channel showing how I set the beat
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be. You've signed up to another forum !!! Why you defector , you snake in the grass, you infidel consider yourself shunned.... you.......you........you CAD  😅😅😅😅😅😅🤪
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
