UPDATE on porcelain dial soldering
Ok i finally did it, not the best job but def will pass my standards. The 60 is slightly off, the weld was a bit shabby but ok. I ended up using a tool for wood burning, its does not heat up as much as a solder iron. There is a tiny chip by the 50 that occurred when removing old sub dial, kinda pisses me off the most because without that would have been dam near perfect.
Edited by saswatch88
1 hour ago, saswatch88 said:
I didn’t have to solder on the feet, that i could never do
Sorry, I meant the sub-dial. What is the substance that you add when soldering ? (not very knowledgeable on this topic but I want to know more)
i just moved the solder that was already there over in order to release the sub-dial then installed new one then pushed the solder back over.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
