Russian Watch w Liquefied Gasket
monastic
I have a Russian wristwatch with what I assume is a vintage electric movement (transition between mechanical and quartz). It's attractive and it runs, and I want to keep it that way.
HOWEVER -
The old gasket has turned to sticky nasty goo, and the goo is holding the movement in the case around the inside of the dial. I don't want to ruin the movement or get the dial face dirty trying to get the assembly out of the case, but it's stuck in there tight. Even so, I have no idea how to clean it once I have it apart. As a test I've tried letting the back parts sit in soap before washing them off. And when that didn't budge the tar, I tried GooGone - also to no avail.
Anybody with experience here, please help. Thanks!
Edited by monastic
Typos
What a mess. Ronsonol lighter fluid and a box of cotton swabs, with lots of caution. That ‘s one option. I’ve used it to do that and it also will not usually affect any of the painted parts. Other solvents will ruin the dial or crystal. Steve
Sent from my iPad using Tapatalk Pro
If all else...consider reassembling the back, removing the bezel and gently using compressed to pop the crystal while wrapped up in a cloth. Or use a crystal lift if acrylic. Then remove the back and hands and gently pressing from the dial side (protected) while softening the goo with heat from a hair-dryer.
Good luck!
Sent from my BBF100-2 using Tapatalk
9 hours ago, yankeedog said:
naphtha and a box of q tips
My mind went straight to "naptha and a box of matches" - Tempting...
Great ideas from everyone and I'm pondering which to try next. Likely won't get back to it until the weekend, but I'll be sure to let you all know what happens. Thanks!
Edited by monastic
Reporting back. Here's what worked: Hand sanitizer.
Decided to give it a try since none of the other conventional cleaners were touching it. Best thing ever - it dissolved the black goop immediately and it wiped away easily with bud swabs and Scott tissue. It works really well removing Sharpie marker and tape goo, guess gasket removal goes on the list, too.
Monastic, would that be the pump bottle gel type? I'm surprised that would have enough solvent to dissolve the rubber goo but I love learning something new like this. Please share what type you used.
Come to think of it, some of those products do have alcohol in them, maybe that was the ticket...
Edited by watchabit
I have used several brands of hand sanitizer for cleaning felt marker and other kinds of tenacious stains and goo off of smooth surfaces.
The ones I have all over the house right now are little flip-cap travel-size bottles. They all use ethyl alcohol as the active ingredient - 60% to 70%. The specific one I used on this Russian watch is a Safeway brand product. It compares itself to Purell, but states that it is not made by GOJO, which makes Purell.
I don't know squat about chemistry, but I wonder if the gel element keeps the alcohol from drying out before it can liquefy whatever goo it needs to so it can be wiped away? I can't tell that it leaves a residue either.
Edited by monastic
OCD
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
