S Dockerty
Hi I have  a Swiss Emperor Chronograph
17 Jewels with a
valjoux 7733 hand-winding movement
Unfortunately it is missing the crown and possibly the winding stem. Would anyone  know where I might be able to purchase these items or help me identify them with any part numbers etc.
Thanks you in advance for any help
Yours Shaun
Do you intend do the work by yourself? Stem needs to be cut to length, which is not difficult but better done by a watch repair shop. That would also be a good occasion to fully service the watch in order to have it regain original performance and prevent wear.  He would be able to supply parts otherwise you can purchase from Cousins UK.
  • 4 years later...
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
