What tool do you use to regulate?
mousekar
Hello All,
I'm wondering what tool is commonly used to manipulate the regulator arm? I've used everything from tweezers to a plastic stick used to help open up computers. My main issue is that all of the things I've used are risky for slippage and I find it incredibly hard to just nudge a little when you're really trying to dial in the timing. I would think there would be a special tool for this (there's a special tool for EVERYTHING), but I haven't managed to find such a tool if it exists. Today I made my own tool using an old broken spring bar tool that I reshaped that should make life a little easier, but I'm very curious to see what everyone else is using.
thank you
I'll bet you if you take a small screwdriver tip and make a small V in it, it would prevent and possibility in slipping. This will now work for pocket watches of course. Thoughts? Or do the same with a long thin piece of brass so less steel on steel contact.
Sent from my GT-N5110 using Tapatalk
  • 7 months later...
I wrote about such a tool somewhere else in the forum which I called a "regulator arm tool". It can be easily made from an old screwdriver.
It straddles the regulator arm from the top, so that reduces the chance of slipping and damaging the hairspring. It also gives much better torque control allowing very small adjustments of the arm.20200712_093708.thumb.jpg.84a9ad635fd74e2d673c0b33f3654993.jpg
It straddles the regulator arm from the top, so that reduces the chance of slipping and damaging the hairspring. It also gives much better torque control allowing very small adjustments of the arm.http://d1v6dnm22vfd7d.cloudfront.net/monthly_2020_09/20200712_093708.thumb.jpg.84a9ad635fd74e2d673c0b33f3654993.jpg
Great minds:)
  • Similar Content
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
