Antique show haul part deux!
FLwatchguy73
Today was the second of 3 annual antique shows in Mt. Dora, Florida. The weather was gorgeous and the prices were right! And yes,  I know,  I have a little problem... im sure many of you can relate to that problem,  lol. Most were Timex's, with a few misc brands.  The lucerne chronograph will be challenging to say the least,  it has definite issues. These span close to 40 years,  50s, 60s, 70s and 80s. Should be fun getting these going again.  @JerseyMo... I'll be putting a shopping list together for you shortly:D
The prices of these were fantastic, none except the lucerne were over $10 each, must were under $5 each!20200118_182536.thumb.jpg.71f9252c158dcf834c51f10a20c27d8a.jpg20200118_182554.thumb.jpg.f17ddf53a1507e051ac5a72588583e22.jpg20200118_182600.thumb.jpg.979d5d104b3f90e5ee9bbfbaa680c114.jpg20200118_182608.thumb.jpg.a5c8504f41f93b4719ff0ce6a75fd33d.jpg20200118_182611.thumb.jpg.9de729dde456352290d8111350842f02.jpg20200118_182728.thumb.jpg.d0212b8eec703b64f9f9c42c717ab5ba.jpg
(Apologies for the picture flood.. thank you for your patience)
Edited by FLwatchguy73
20 minutes ago, JerseyMo said:
fantastic haul.
Awesome day all around.  Hardest part was deciding what to get and what not to get,  so much to choose from. My youngest child had a skeleton key groove going on today. I got her a chain so she could wear a couple around her neck.
1 hour ago, watchweasol said:
Well  what a haul was Mrs with you or has she given you up as a hopless case, did you have enough room in the car for them all.:D
My pockets were bulging,  lol. The Mrs. Didn't come along.  Antiques and watches are not her thing,  which is probably a good thing, the less she knows,  the better!:D
1 hour ago, FLwatchguy73 said:
. What model is the  one from 1958?
the white dial self wind is from 1958 and the model is named 'Viscount'   they aslo came with a black dial and most f the old Timex forum members consider those a grail watch.   Yes, and no need to askas I do have two of them.
BTW, the movement is a model 29.
One each of the black and white dial I'm guessing?  Though I did see one with gold tone numbers and hands on a white dial online.
Roger Chaffee (Appolo 1 astronaut who tragically died in a capsule fire along with Edit White and Gus Grissom) owned one of these (below).  NASA has it on display at the Kennedy Space Center.
Im pleased to see mine looks nearly identical to his above.  I own this photo, as I took it on a visit this past summer.
next time you go ,you can borrow my truck.
Just wanted to give an update on the overhaul status of my antique bounty. By the numbers,  In total,  I acquired 21 watches at that show. 15 of which were Timex's. Only the pocket watch and the West end watch required no mechanical servicing. Everything else required a full service. The top row of watches will require parts or there are other significant issues.  3 in the top row are in fact Timex's , one only needs general servicing,  one needs parts ands one suffered from my ham handedness!:unsure:
11 out of 15 Timex's are 100% with a 13th soon to be added. One of the 15 Timex's runs like a dream,  I just need a case and stem.
Not to be a shill for  Timex, but damn! Their simplicity and robust design have turned them into impressive timekeepers. All in all im impressed with them and very happy with the watches I've acquired. Next Saturday is the 3rd antique show.  If I get anything, I'll be sure to share.
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
