Mainspring winders
4 hours ago, transporter said:
I did ask my Chinese seller what they were for and they said they will get back to me, so when they do I’ll post here.
I love the fact even the sellers aren't sure what they are for.
:D
Retail sellers, including Chinese ones, are exactly that. You can see they often stock all kind of items, including lingerie, in order to make an honest buck. Is not like they have to know the in and outs of the product that they did not design, did not produce, and was never explained to them.
Hi, I bought one in early Jan as well from ebay paid £70 for it. I have used it once on an ETA 2671 and worked a treat i did disassemble then clean the winder first as it was coated in oil and had brass swarf here and there. Im happy with mine and pleased I bought it just hoping  I can use it on AS. movements and a few Seikos. Will post a few pics in the morning.
I've got most of the above winders. Including some that claim that they have adjustable barrel size. But watches in those days must have really different from what I have been working on. It usually doesn't fit properly or is the wrong size arbor.
I wished someone would make 1 that was truly universal. 1 that can do both right and left hand wound. Have different size barrels and arbors that you could select and assemble together to fit the watch that you are working on.
The Bergeon ones are nice but really expensive. I've seen China made copies recently. But I don't know if they really work.
Hi
The most common sizes of barrel drum sizes (outer diameter) at my workstation are between 9.8-10.8 mm.
Would a winder no. 7 (10.8 mm) cover the most then?
Besides, I might order one size lower and higher as well.
Made an offer that was accepted on this mainspring winder set.  I have been researching and asking questions so hopefully I got a decent set?
There are so many options and many are quite expensive- I didn’t want to lay out hundreds of dollars only to get the wrong sizes...If I made an error it is not a costly one :)
I have a very similar set, and they can work well if everything goes right.  I would highly recommend practicing on some expendable mainsprings before you attempt an expensive or hard to replace mainspring.  I mangled quite a few getting the hang of it.
I have a similar set. Be careful, on the set I have some of the notches that grab the mainspring are worn and tend to let go if not careful. I do have several mainspring winders but my favourite is a "Mastercraft Winder". which is 100% reliable. see pics.
Mastercraft winder.jpg.pdf
Mastercraft 1.jpg.pdf
Mastercraft 2.jpg.pdf
Reviving a bit of an old thread that I found during search - I've been looking at the Chinese set as well, but I have a question for the "hand-winders" on the thread - how do you deal with automatic mainsprings? When I do hand wind, it's from the outside in (the reverse of how the spring comes out of the barrel) and the split ends / extra pieces of automatic ends are especially tricky. I feel like there's no good hand-winding technique for these springs and winders are the only option.
Thanks
All of the watch mainsprings I'm aware of can potentially be hand wound into the barrel, some are just more tricky than others - some shapes or types of mainspring can be awkward regardless of method. Having a pre-wound mainspring is nice when everything is going to plan.
The strange thing with this set is it's not a general-purpose sets which I think would be more useful. In other words is made for specific calibers. Then they didn't clone the handle the way it normally should Look? Plus there's no mystery pieces?
So for instance here's a link to the eta set and And a PDF with a few more details.
https://www.bergeon.swiss/assortiment-de-12-estrapades-pour-calibre-eta.html
Here is a link to the general purpose set. With an added bonus the PDF here is much much nicer as It explains how to use the Winder.
https://www.bergeon.swiss/assort-estrapades.html
Indeed, and that's what I'm waiting for. I have a K&D 128 winder, but I've come to dislike it a lot. When I use it it is a 50/50 chance I succeed or mangle the spring. Perhaps it is me, but I'm thinking that as I could learn how to handle cap jewel springs quite well (even diafix springs) why shouldn't I be better with my K&D 128 winder. The Bergeon winders are just insanely expensive. I've been considering the Bergeon 5355 and complement with larger winders, but it is still a fortune and I can buy "a bag" of new mainsprings for the same money.
Edited by VWatchie
Good Morning to you all I hope you are all keeping safe and well,I wonder if anyone can help me with a small problem I have.I have a set of old watch mainspring winders which I use and they have become rather worn on the mainspring hooks on the winding arbors.Does anyone have any ideas on how to replace the hooks on the arbors?? Any help would be gratefully received,I enclose photos of the winders,Regards,Seth.
Hi Seth
I can see that the hooks are worn. My advice is find a kind engineer to create a new hook on the winder stem using a gouging chisel. If you look carefully you can see that a chiseling tool was used to make the hook. You could try it yourself using an old masonry drill bit with the tip ground to a chisel shape to the width of the gouge in the stem. Trap the winder securely in a vice and if you put the masonry chisel in  the gouge at the right angle then tap the end with an hammer being very careful not to hit too hard you should be able to move the metal to form a new hook. I would practice on a scrap piece of steel such as a nail of the same diameter first.
Hope this helps.
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
