Mainspring winders
9 hours ago, Gasman said:
I bought this set and used for two eta calibres and they worked fine.
Quality is good though I had to degrease them as they came swimming in oil!
Hi Gasman, thanks for the reply. Just what I was hoping for.
Can you add to or correct any information in the list below? Ideally, would you be kind enough to list the actual spring diameters / heights which fit in each winder?
2000?
2671 = 6.5 dia.
2235 = Rolex according to Rogart63, but Ranfft doesn't list details.
8200 = Miyota according to Redwood, but Ranfft doesn't give a mainspring dia. It's apparently a sealed barrel.
8500-1?
8500-2?
3135/2824=11.0
C07111?
7750=12.5
2892/2836=10.5 or 11.0
Do you see any reason why they would only work with the listed calibres?
What is the difference between the 3135/2824 winder and the 2892/2836 one?
Are these exclusively right-hand winders?
I am very interested in the diameters as well.
The mainspring winder I have is an antique set which belongs in a museum in stead of being used. And does not function very well.
I also found this set on Ebay. And I even saw it on Aliexpress for around €78 incl shipping.
https://a.aliexpress.com/lkEw5Nax1
But nowhere I can find which exact measurements the barrels have.
To start with it is described as vintage (vintage today doesn't mean what it used to be) I have seen clocks made about 10 years ago called vintage. This is a set for E T A movements, it doesn't mean that you should only use them for there movements,but on there movements they will work better and be a better fit.
For what its worth I couldn't get along with watch mainspring winders, so always wound them in by hand.
Me too
I think its pretty standard for most tools Horological tools to not come with instructions, even the expensive ones (Timing machines excluded) much to my annoyance.
I guess the idea is if your buying an expensive watch makers tool you should of already completed some formal training that has taught you how to use the tool.
Are the two brass tubes identical to each other, or do they have different inside diameters?
The part of the winder you hold in your hand that has the plunger in it doesn't fit nicely inside the tube does it?
Just wondering if its somehow to make it easier to hold being it is so short compared to the Bergeon one
This is how they fit: loosely over either end. Bottom ring can't fit this way in use as the diameter on the barrels are too wide. Having it over the plunger end would be counter productive as well as the plunger doesn't come out far enough through the top of the ring. Also there are two nice cutouts on the included platter for these to fit in. From what I can tell with my relatively limited watchmaking experience this kit functions perfectly fine without them. But there has to be a reason for them to nicely machine out and anodize 2 pieces of aluminum as well as their respective cutouts on the display platter. Very intriguing.
Edited by CaptCalvin
On ‎1‎/‎17‎/‎2020 at 4:20 AM, watchweasol said:
Having had a look on the web It seems most mainspring winders come with these barrels but nothing much in the way of instructions, I will have to look harder. Never having used one, always used my fingers had no problems.
    the thumbs have it !      vin
cant help you im afraid but im also going to get one of these sets, ive been wondering when the chinese market was going to make mainspring winders and here we have a half decent set. I did put a best offer on a set on ebay but the seller refused my offer and counter offered a price £1 lower than the asking price..
I shall take my money to aliexpress where i can get one for £30 less than ebay
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
