Mainspring winders
But sometimes the arbor does not fit the mainspring for the correct size barrel and/or the other way round so it is useful to have a set - but even my set with 17 barrels both left and right hand cranks will not fit every mainspring/barrel combination, but the more sizes you have, the more chance you will have that you will have a correct combination.
I was looking at this mainspring winder set which is for sale.  Does anyone have any experience with these?  Will they handle most wristwatch sizes?  I am trying to get the model number to see if I can find any more info regarding these.
Cheers!
Roger
Unfortunately, I lost the opportunity to buy the Watch-Craft set shown above.  Has anyone used the K&D 127 or 128 Mainspring Winders shown below?  Will both do wrist watches (I am not working on pocket watches)?  Any insight would be appreciated.
Cheers!
Edited by 64americandeluxe
Here is another set that I am looking at (see below).  Any advantages or cons to using the KD 126,127 or 128?  It looks like the only difference between the 127 and 128 are the barrel sizes they'll accept.  The 126 is the "Robbins Type" but I am not sure what the significance of that is.
Thank you!
Roger
Oh.. anw for some mainspring i managed to fit into the mainspring winder. But when i wind almost gonna complete it and it suddenly pop up and broke the mainspring. Why is that so? Am i doing something wrong? Do i need to flip the mainspring and put it into the mainspring winder? And sorry for this question does flipping the mainspring will causes anything? Thanks.
Hello. Watchcraft mainspring winders can be used to wind right hand and left hand so they are a good starter to begin with. Some mainsprings are left hand wind or right hand wind so the Watchcraft will work , but they are not the quality of a set of Bergeon winders which come in right and left hand wind sets or combined.
I find the most K&D's winders are ok for pocket watches but not all of them fit most wristwatch barrels.
Excellent information!  Thanks very much!
Roger
Not quite certain what happened from your description.
  • 5 weeks later...
Hi I was just looking at mainspring winding tools and as someone who is new to this think they are a big expense for the new coming is there anther way of putting in a mainspring with out the tool, or do new springs come ready to fit ?
To be done correctly and more importantly Safely...you really should use mainspring winders to fit mainsprings. There are instances where they are not needed, when the mainspring is held with a girdle that is smaller in diameter than they barrel. These can be installed directly into the barrel from the girdle. But, then again, I usually remove the girdle and inspect, clean and grease the mainspring before installing it. So, I still use a winder set.
There are some deals on used sets out there but I've bought poor sets along with really good sets. It's hit or miss, to be honest!
I bought a used set of Watch-Craft mainspring winders for wrist watches recently and they were very reasonably priced.  I used them for the first time this past weekend (first time ever winding a mainspring) on a mid-1960s Elgin and found the experience quite easy.  I installed and removed the mainspring about 3 or 4 times dry to get the hang of it and then oiled it and reinstalled it.  With the winder, I found the removal and reinstallation of the mainspring much easier than I was expecting (many comments online left me apprehensive about doing this but I was very eager to learn this aspect of watch repair).  For me, winding and installing the mainspring back into its barrel was much easier than trying to align the three pivots on the train bridge!
Cheers!
Roger
  • 4 weeks later...
I'm looking at getting a mainspring winder, the likely candidate being the Bergeon 5355 there's not a lot else thrown up in searches but before I commit is there a better alternative? Occasionally people can recommend a genius of a Chinese alternative to things...
Lee
I have purchased cheap mainspring winders in the past and they have been terrible. In the end I plumped for the 5356 Set. It serves both left hand and right hand mainsprings. But I find mostly that I use sizes 4, 5, 6, 7, 8 and 9
Most swiss movements use the clockwise wound handle and cranks and I find the anti-clockwise handle and cranks useful for Japanese (like Seiko).
There is a special ETA set, but I find #8 is OK for the 7750 and using size #7 with #6 crank (carefully) works well for 2892-A2 and 2824
The rest in the set I rarely use.
  • 5 months later...
So, I'm on the market for a set of mainspring winders and I had a few questions. The main options I can see, in terms of second hand or used, winding tools seem to revolve around:
1. Watch-Craft Bracelet Winders: Sets of 8 in sizes 5mm to 10mm.
2. Bergeon 2729 Winders: Single handle; set of 7 barrels in sizes 0 (5.6mm) to 6 (9.8mm).
3. JC Schilling Bracelet Winders: Much the same as the Watch-Craft ones.
4. K&D 123/128 Winders: Set of 7 barrels and bench vise base. Their sizes tend to be vague but the 128 seems to start from 8mm.
I suppose the worry with 1-3, is how likely is it to need anything larger than 10mm, and how to deal with any left handed mainsprings? Any recommendations or advice? If it helps, I intend working on vintage watches which will primarily date prior to 1970s, so I'm hoping the 10mm upper size on most of these is not an issue for a beginner green looking newbie like me ;).
At present, leaning towards the Bergeon though the Watch-Craft's are more readily available from the US (which makes them more expensive as it happens if you throw on customs + VAT).
Then again, I just spotted a Bergeon set that went for close to £260. Seems the Watch-Craft are a fair bit cheaper overall... Checking the non-local ebay sites to find a few more samples. Looking at older forum posts elsewhere, the prices have gone up in the past year or two for used winder tools.
Edited by PadraicB
I have a K&D winder but do have problems with small watch springs. Releasing the winding notch from the newly wound spring can be troublesome & I have destroyed a few with this problem. It might be because it is an old vintage one but I think it is just the design.
If my finances improve hope to purchase a Bergeon or at least a barrel type winder they seem to offer a lot less hassle.
I don't know guys but in my case I've been pondering about winders and although it would be nice to have a good quality set, the volume I handle doesn't justify the expense therefore I always do them by hand. Somehow it keeps me "closer" to the watch! :)
It is good to know about the K&D glitch, clockboy, since I've spotted some on eBay occasionally and I've been tempted!
    • Put the movement in a movement holder and it will be supported as you push down on the setting lever post to release the winding stem. Make sure the post is over the shoulder of the movement holder so what you are pressing down on is supported. As a general rule, hold the movement and not the movement holder. Replace the hands when the movement isn't in the case and support the centre jewel (if it has one) on a hard surface or staking block when replacing the hands to stop the jewel accidentally moving or even coming out. A dedicated movement holder with a central jewel support is even better, but pricey
    • It might help us if we knew which watch like model number.
    • Hi, guys I have a bit of a predicament and hopefully, somebody can advise. I'm working on a Roamer MST 521 where the movement is extracted from the crystal side. I'm now at the final hurdle where I need to replace the movement back into its case but I'm not sure of the correct procedure. I still need to fit the hands but that's where the problem lies. If I insert the winding stem to test the hands for correct alignment I will need to turn the movement over to release the stem again it's the spring-loaded type and needs a small bit of force to push down but with the hands fitted, I don't think I can do this on a cushion without causing some damage to the hands and that's the last thing I want to do, this watch has already been a love-hate relationship and I'm so close to boxing this one off which I'm counting as my first major project.  The other option is to case the movement then fit the hands and hope everything is okay. I've already broken the original winding stem but managed to find a replacement, the last one in stock, so I'm a bit reluctant to keep removing it. Any suggestions would be appreciated.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
