Good Morning - Mark from UK
Emsworthian
Morning all,
I'm a complete novice when it comes to watches, but have certainly caught the bug over the past couple of months.  Started with a 'Build your own watch from eBay parts' (with help from the excellent YouTube videos), and now I've moved on to the servicing/repair of a Seiko 5 with 7009 movement.  I have three observations from my initial foray:
  1. If there is an opportunity for anything to spring from the desk, it will
  2. Chances of finding something that has left the desk is about 10%
  3. It is going to take a while to become proficient with tweezers
My passion is repairing and restoring anything vintage, the last project was a 1963 Land Rover - sadly very little crossover in tooling!  For me, the process of restoration is almost more important than the end result.
I would like to find a few more Seiko 5's for repair and would welcome any guidance about sourcing watches for repair.  eBay is the obvious place to look but I'd welcome alternatives, thanks.
Mark.
Hi Mark,
Ohh nooo another competitor on ebay!!! :) Welcome to the forum. :) Watch Mark's videos and read books, its an amazing an exciting territory of life I just recently discovered. Watch your seating position and have a good light. Basically follow the advice is given by Mark or by the books. I was planning to buy a rolltop desk which would catch some of the parts flying, but could not find a place for it yet in the house. I am still rather screwing up watches rather than servicing them and everything takes a long time to master. :) Things which are 5 mins for Mark I can sometime spend 2-3 hours or a few days, beeing on my knees looking for parts, braking them and trying to find another part in my pile, trying to make something but I fail to do so, forgetting something to put in, scratching the movement/dial, ohh and the hairsping is beating even Freddy Krueger. Still its worth it.
lui
Welcome to the forum Mark I see you have already found some of the problems of watch repair.  I doing somthing trickey and there is a possibility of an escaper like clicks and click springs etc, work in a large plastic bag,       Not you        the watch it limits the distance the bit travel
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
