Westclox/Seiko
yankeedog
Hey All,   a few of you have noted that  you were unaware  of the connection. But yes westclox  did assemble  Seiko  movements  into their  cases. Much like Seiko sells bare movements  to third party  assemblers today. For your pleasure  I have included  a picture  of the movement  in the westclox  recently  posted  in the watch of the day.
I  am not exactly  sure. I believe  there are some  differences. For example  the train  and barrel  bridges  are separate  pieces..I think that  on the 66 they  are one piece. I don't  have an actual  seiko to compare  it with. But from what I have seen  that is what it is.
  • 3 months later...
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
