Seiko 6309A Pallete Fork
vext01
Hi everyone,
I've been stripping/cleaning/reassembling a Seiko 6309A movement.
I'm new to this, so mistakes were made. During reassembly one of the stones on the pallet fork has detached.
This leaves me in an awkward position, as I doubt I have the skill to re-attach it and according to cousins, this fork is obsolete.
I've seen replacement forks from abroad on eBay, but they are expensive. Does anyone know where I could get one in the UK?
Thanks!
3 minutes ago, vext01 said:
Thanks. Looks like this site has the part, but do I see it right that it's  €11,95 postage to the UK?
Read below: "Small orders below 25 euro can be send by regular mail (€ 2,95). It takes longer!"
I can vouch for speedtimerkollection, used him many times and no hassle. For clarity I’m not involved in any way, just a happy customer.
Ps: you could always learn to fix it yourself?
2 minutes ago, jdm said:
Very hard to get new parts for a 50 yrs old mov't like this.
Schillachi61  has new forks. But cost 9.99 . He is in UK so  won''t be that much shipping . I  have his email adress if you like.  Maybe  a couple of quids cheaper? Send me a PM
Or keep scouring the bay and you may find a movement you can cannibalise. But that movement may have unseen issues meaning you’d be back to looking. Or if you’re like me it’d just mean you have two movements you want to fix instead of one! [emoji23]
11 hours ago, vext01 said:
Hi everyone,
Thanks!
First and foremost lets figure out why did the stone come loose, how did you clean the movement and what solutions did you use?
gunna be almost impossible to find a NOS one if one is found it will cost about as much as a complete movement or even a complete watch will cost. So you have to make a choice on which route you wanna go.
Keep in mind Seiko pallet forks are mostly interchangeable. off the top of my head a pallet fork from a 6106, 6119, 7002, 7009, will work as well and there are others.
Luckily someone on Facebook has offered to send me a spare! I can't believe my luck.
As for cleaning.... Bear in mind that I'm very new to this and I'm operating on the cheap until I know this is a hobby I want to pursue...
For most of the movement I used first a weak solution of dish detergent, then a wash in IPA alcohol, before a dip in a final uncontaminated pot of IPA. However, I did not clean the palette fork at all, because I read in a book that the adhesive used on the fork breaks down in solvents. (I also didn't clean the balance for fear of breaking it).
I know that ideally you'd use professional solutions and machines.
The stone actually came loose as I was re-fitting the bridge. The watch suddenly let all of it's power out in a great "whiiiiz". Perhaps I shouldn't have had power in the spring whilst fitting the escape bits?
Ah! That's good to know. I did look at a spare fork I have from a fake 7S26, but it was visibly smaller.
never had A pallet stone come loose in that manner. Could have had a bad cleaning previously. You def. cleaned it correctly by not using the IPA on the pallet and the balance.
You should not have power in the spring until you have everything installed up to the pallet fork, in my case i dont wind it until the balance is installed. But either way none of this would have caused stone to come loose, so its anyone’s guess why it did. And Yes The 7s26 pallet is different.
8 hours ago, vext01 said:
Thes stone actually came loose as I was re-fitting the bridge. The watch suddenly let all of it's power out in a great "whiiiiz". Perhaps I shouldn't have had power in the spring whilst fitting the escape bits?
I think what happened is that you fitted the pallet fork with a stone over a tooth, maybe even positioned its bridge, then wound the barrel, somehow the pallet was able to hold power for a while before the stone was dislodged while tighteining or being hit by the spinng escape wheel.
Personally I find fitting the fork pallet a very delicate task and have had some breakage while doing it, we aren't all born master watchmakers! One must be 100% sure that both pivots are in place before tightening the bridge, for that observe the stones correctly engaging teeth, and the bridge being level. Only then wind the barrel to try the fork flipping when slightly touched, which is a correct procedure.
Regarding your cleaning procedure it is not necessary to use expensive solutions and machines (even if you can read some insisting advise to the contrary), but use of dishwasher soap for the movement is kind of unheard, better would be petreoum ether to dissolve old oils, followed by demineralized water, and then IPA.
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
