Seiko 6309A Pallete Fork
vext01
Hi everyone,
I've been stripping/cleaning/reassembling a Seiko 6309A movement.
I'm new to this, so mistakes were made. During reassembly one of the stones on the pallet fork has detached.
This leaves me in an awkward position, as I doubt I have the skill to re-attach it and according to cousins, this fork is obsolete.
I've seen replacement forks from abroad on eBay, but they are expensive. Does anyone know where I could get one in the UK?
Thanks!
3 minutes ago, vext01 said:
Thanks. Looks like this site has the part, but do I see it right that it's  €11,95 postage to the UK?
Read below: "Small orders below 25 euro can be send by regular mail (€ 2,95). It takes longer!"
I can vouch for speedtimerkollection, used him many times and no hassle. For clarity I’m not involved in any way, just a happy customer.
Ps: you could always learn to fix it yourself?
2 minutes ago, jdm said:
Very hard to get new parts for a 50 yrs old mov't like this.
Schillachi61  has new forks. But cost 9.99 . He is in UK so  won''t be that much shipping . I  have his email adress if you like.  Maybe  a couple of quids cheaper? Send me a PM
Or keep scouring the bay and you may find a movement you can cannibalise. But that movement may have unseen issues meaning you’d be back to looking. Or if you’re like me it’d just mean you have two movements you want to fix instead of one! [emoji23]
11 hours ago, vext01 said:
Hi everyone,
Thanks!
First and foremost lets figure out why did the stone come loose, how did you clean the movement and what solutions did you use?
gunna be almost impossible to find a NOS one if one is found it will cost about as much as a complete movement or even a complete watch will cost. So you have to make a choice on which route you wanna go.
Keep in mind Seiko pallet forks are mostly interchangeable. off the top of my head a pallet fork from a 6106, 6119, 7002, 7009, will work as well and there are others.
Luckily someone on Facebook has offered to send me a spare! I can't believe my luck.
As for cleaning.... Bear in mind that I'm very new to this and I'm operating on the cheap until I know this is a hobby I want to pursue...
For most of the movement I used first a weak solution of dish detergent, then a wash in IPA alcohol, before a dip in a final uncontaminated pot of IPA. However, I did not clean the palette fork at all, because I read in a book that the adhesive used on the fork breaks down in solvents. (I also didn't clean the balance for fear of breaking it).
I know that ideally you'd use professional solutions and machines.
The stone actually came loose as I was re-fitting the bridge. The watch suddenly let all of it's power out in a great "whiiiiz". Perhaps I shouldn't have had power in the spring whilst fitting the escape bits?
Ah! That's good to know. I did look at a spare fork I have from a fake 7S26, but it was visibly smaller.
never had A pallet stone come loose in that manner. Could have had a bad cleaning previously. You def. cleaned it correctly by not using the IPA on the pallet and the balance.
You should not have power in the spring until you have everything installed up to the pallet fork, in my case i dont wind it until the balance is installed. But either way none of this would have caused stone to come loose, so its anyone’s guess why it did. And Yes The 7s26 pallet is different.
8 hours ago, vext01 said:
Thes stone actually came loose as I was re-fitting the bridge. The watch suddenly let all of it's power out in a great "whiiiiz". Perhaps I shouldn't have had power in the spring whilst fitting the escape bits?
I think what happened is that you fitted the pallet fork with a stone over a tooth, maybe even positioned its bridge, then wound the barrel, somehow the pallet was able to hold power for a while before the stone was dislodged while tighteining or being hit by the spinng escape wheel.
Personally I find fitting the fork pallet a very delicate task and have had some breakage while doing it, we aren't all born master watchmakers! One must be 100% sure that both pivots are in place before tightening the bridge, for that observe the stones correctly engaging teeth, and the bridge being level. Only then wind the barrel to try the fork flipping when slightly touched, which is a correct procedure.
Regarding your cleaning procedure it is not necessary to use expensive solutions and machines (even if you can read some insisting advise to the contrary), but use of dishwasher soap for the movement is kind of unheard, better would be petreoum ether to dissolve old oils, followed by demineralized water, and then IPA.
    • I still need to see the complete movement as there are many types of Elgin movements. The part that you are holding is called a snail.
    • Just a quick update on my T17. I just finished the service and, boy, was this nerve-wrecking.... I bent the hairspring a few times. Stupid accidents. Once it was beyond repair and I had to get a donor movement. The replacement hairspring turned out to be a few millimeters shorter and therefore the watch was running 6min too fast even when the regulator was set to the slowest position. So I needed to get timing washers (see another post here: https://www.watchrepairtalk.com/topic/25505-30t2-adjustment-of-timing-washers/?do=findComment&comment=248100).  After all, I'm now, getting a 310° amplitude (fully wound, dial up, lift angle 54°). About 250 in vertical positions. Quite a drop, but apparently not too abnormal for a 90-year-old watch with a slow beat rate (18000bph) and rather heavy balance wheel. After 24h I still get 280 (horizontal) and 220 (vertical). And now the highlight:  66h of power reserve! You may remember that I posted that I used a slightly weaker, but also slightly longer mainspring than prescribed. See my comments above.  I used GR 3937 (instead of GR 3632). So I recommend this mainspring and ticker oils (9020 on escape wheel and HP1300 on the rest of the train).
    • OK! I was able to get a nice set of timing washers from ebay! And they worked really well. I needed to slow down the movement by about 6min and I put four (=two pairs) of 3-minute washers (rated for the the size of the movement) and it did pretty much exactly that. On one pair of screws, there were already washers. So I added a second washer on those screws. Maybe not ideal, but it doesn't cause any problems. Poise is ok.. not perfect.. but I had so many issues with the watch that I decided to accept it. It's a 90-year-old watch. Delta is around 40 seconds.
    • I think it is friction fit, there are tools to remove them, cheaper versions are available. You could try adapting some pliers, see my crap drawing.  The pushers are available in various sizes, you could measure once the tube is removed.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
