Modified Vostok-Europe K3
Klm
It's the older 41mm k3 (2007) I replaced the dive bezel with the "pan" bezel . These watches have a big problem with the crown threads stripping so I put a Vostok crown tube in it with a Vostok floppy crown  so a much better seal .  Also ground off the crown guards and a extensive sanding and polish to the case .
