Balance jewels and end stones
rduckwor
I'm working on an Elgin 712 movement and was about to go to a scrapper movement for the main plate until I found this: (first picture).  An end stone with no visible means of support. No spring, no screwed setting ring, nothing holding it in until I ran it thru the cleaner and it fell out.  Upon further examination, I found this:  (picture two).  Lots of glue in the setting.  Now the movement I am working on has a KIFF spring over the end stone (picture three).  I checked the second scrapper in my pile and it too has no visible means of support for the balance end stone and I suspect that it too is glued into the setting.  Neither scrapper setting has cut-outs for a spring insertion.
Was this ever a common practice for manufacturers?  I know Elgin has some special glue for hairspring collets and studs, but jewels?
Thanks,
RMD
Sorry if i find the post a bit confusing but we are talking about the balance cap jewels, picture 1-2 is one movement and picture 3 is a different movement but same caliber Elgin 712? If all 3 pictures is of a balance end stone/cap jewel  then the only one that looks correct is picture 3. Elgin 712 movement does indeed have a shockspring on the balance. I have seen friction fit pivot jewels for the train which seems to be what this has after looking on ranfft but it would never be on the balance.  One thing I can say for sure is there will never be any kind of glue on any balance jewels with a shock spring, because that would defeat the whole “shock resistant” purpose. I would also say the same for non shock resistant movements.
Elgin had several styles of Springs to hold the jewels in place. I think what happens is watchmakers will lose them and shove in something else. Then you will note that these are not necessarily shock resistant jewels only Springs for holding them together.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Elgin_712
That's the one I was thinking of.  The "lyre" shaped spring.  I simply could not remember what it looked like when I was working on this movement.  That would certainly fit this setting WITHOUT the cut-out for the KIFF spring.
Yes, they weren't shock settings. I remember reading in an Elgin publication how they crowed about this spring and the reductions of "lost" screws for the people servicing their movements.
Thanks,
RMD
" Sorry if i find the post a bit confusing but we are talking about the balance cap jewels, picture 1-2 is one movement and picture 3 is a different movement but same caliber Elgin 712? If all 3 pictures is of a balance end stone/cap jewel  then the only one that looks correct is picture 3. "
Saswatch88:  the first two pictures are intended to show the setting for the cap stone and the glue I removed from said setting.
RMD
Hmm that’s weird never seen that before but after looking at a stock Elgin 712 it doesn’t have any other jewels which are held in by a spring except for the balance cap. If these springs have been used to keep jewels together then i would suspect other than the balance it would only be on the escape wheel since normally you dont see cap jewels on anything else, and cant see a spring being needed to hold pivot jewels in place. The Elgin 712 did come with a model that had cap jewels on the escape.
Edited by saswatch88
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
