RONDA RL 1223
jthing
Stems for watches are usually referred to with a 'Ronda Number' (and not just for Ronda watches like yours!).
I believe the Ronda Numbers for your movement are 1848 for the standard wind/setting stem and 1790 for the alarm wind/setting stem.
A quick look on ebay gets me this: https://www.ebay.co.uk/itm/RL-RAX-RONDA-Watch-Winding-Stem-x1-Part-401-Many-Calibres-CHOOSE-FROM-LIST/153716373246. If you look through the items available you should see a picture of the 1790 stem. Probably then a good idea is to check your standard stem ... if it is indeed different from this stem then the 1790 is more strongly confirmed as the one you want! You can then get from this ebay source or another source @watchweasol has suggested.
Thanks Watchmaker. I have book marked this on ebay. I will contact seller.
Yes so it is the 1790 you need. If I take the pic from the ebay seller mentioned and put your broken stem next to it this would seem to confirm this:
That reference you've found on ranfft is the Flume number i.e. because Dr. Ranfft is German he uses this company for parts: https://www.flume.de/en/index.html; so it is their part number reference. As mentioned however it is more usual to see the more widely recognised Ronda reference and a company like Cousins lets you buy stems from this number: https://www.cousinsuk.com/category/filter/ronda-stems-by-ronda-number
Thanks WatchMaker. Much appreciated.
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
