Anyone good at lathe work?
Alastair
I have a problem. Ive got this Slava Transistor watch--the one the Russians ripped off in the 60's of the American Bulova Accutron 214....
Its a fairly close match,-- visually they look identical, quite an achievement IMO...
My issue is this. Its third wheel has a rusted off pivot, fairly common on the Accutron version due to moisture or batt leaks and there's fair evidence of a leak in this one..
The Accutron 3rd wheel wont fit--2nd Moscow Watch Co (Slava, Seconda, Vostock etc) in their infinite wisdom made their staff smaller in diameter than the Americans, no idea why... My only solutions as trying to find a correct good third for this mega-oddball are near impossible, are-
1/ machine down Accutron third wheel pivots....
2/ Replace the jewels but dont know if plate holes are the same size and I dont have the equipment to deal with jewel replacement anyway.
So--Anyone good with the watchmakers lathe fancy having a look?
Edited by Alastair
I've repivoted Accutron wheels before, probably the best route for you. I've read that not only the pivots are different but the wheels themselves are slightly different, enough that they don't interchange even with resized pivots. These are apparently exceedingly rare- one source I saw says around 1000 made.
Sorry, I also do not have a watchmakers lathe, YET.  Just spitballing as to why they might be different sizes.  From my experience, companies and even countries use "standards" in manufacturing.  Standards reduce development, as well as, production time and the associated costs of bringing a product to market.  Not just because similar functions get similar solutions, directly reducing their inventory but it eliminates most of the decision making and reducing the associated tooling involved not to mention warehouse space.  If there isn't a compelling reason for doing something different, having a plan already in place certainly helps.
Shane
16 hours ago, Alastair said:
Well,--I had a lathe many years ago, Not a watchmakers one, but as you say it takes a lot of time and lots of bad language till you get it....
--Even then you never stop  learning...
     when i was a kid,  there was a pocket book,  "how to run a _ _ _ _ lathe". a compound lathe,  it helped me get into the aprentis ship.   i still have the book.    vin
18 minutes ago, watchweasol said:
Hi  I have 3 lathes and just about capable of using them not to any degree of being a machinist turn up the odd shaft and the like the fingers and hands getting stiff.
    good show,   age and wisdom,  keep collecting.  vin
Hi--The fact you mention that the wheels are not interchangeable ddoesnt really surprise me. Nothing much does seem to be exactly the same.
I dunno why they did that--Make a not exact clone, Ithought it would have been easier to make accurate copy....
Would you fancy repivoting this 3rd wheel I have? Beer tokens offered.....
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
