Waltham Pocket Watch Challenge
jdrichard
Hey jdrichard,
PocketWatchDatabase suggests that it is a 18s, model 1883.  I can't promise anything but I think I've got some odd 1883 plates and bits.  I printed out the database page and saved the picture.  I'll take a look this weekend.
Hey jdrichard,
Thank you very much. That gear is going to be tough to find
20 hours ago, jdrichard said:
Picked up a Beautiful Waltham PW with a few problem: 2 Cracked Jewels and one loose Jewel, plus missing teeth on a keyless gear.36788911f65a8780f722a336636852b6.jpg821ca39c713ae10db667bfca861601d6.jpg483cabe2fc0cce87a4fe38cb6b21bf53.jpg9140bc9a8687460806b4ca999e248bdc.jpg14fec1cdf5dc5a84a7c55083de12d55a.jpg33e6c8e71a705c080467ec1821d5fc2b.jpg
     good show,  super dial.    i think that dial will fit on many Walthum mvt.s, that will fit into many cases.    im not a "pureist" -- what ever works - and might look good.     vin
It took  some time but after discounting several with to many teeth, I  found the one sitting off to the left.  I believe this is an 1883 but please, don't think it's N.O.S.  If you can measure yours we talk.  This one is 3.9mm across opposite teeth and 1.1mm thick.
Shane
Shane
I will get the measurements and get back asap
Shane
Looks like 3.8ish by 1.1mm: same part, 12 teeth.e6f98baba86514dc14b937f6c9d8e39a.jpg
No problem, it gave me the incentive to go through one of my piles of random.  Gust glad you have one.
Organizations helps move things farther from being liability and closer to being asset.  Only problem is, it's hard to find.
21 hours ago, jdrichard said:
That gear would be very tricky to make on a lathe for sure. The teeth would be a challenge.
    interchangeable parts sometimes have to be ajusted.      a good job for jewelers files .       vin
That is a lot of stuff. I have mine relatively organized and you can never have too much.
Hey jdrichard,
How did you make out fixing your plate?  If you run into an irreparable snag, let me know, I probably have an odd "brass" plate kicking around here.  I wouldn't want to dig it out unless you had the need.
Shane
Hey jdrichard,
Shane
I did bend the peg back into place and the watch now works like a charm. Timed perfectly. Big thanks for your offer. Next time for sure.
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
