First Project Ideas & Help Needed
Background: I know absolutely nothing about how to fix watches. I purchased this Hanowa Swiss Military movement ISA 2330 for $32 on ebay in 2016. I forgot I had it until my other daily watch broke (also Hanowa). After taking it to a watch repair shop to get the battery replaced, we discovered that the second-hand kept sticking. The watch store clerk thought it was the battery, but even after replacing a new one the second hand continued to stick. He recommended doing a "total overhaul". Because I didn't pay very much, I figured it would be a good first project to fix on my own. At first I thought about taking it apart to fix it but trashed that idea when discovering the movement itself is only $16! I guess I expected the movement to be more pricey since a new watch replacement is close to $200. Apologies in advance for those who will shriek at my questions.
So here is what I would like to accomplish:
- A solution that is easy, long-lasting and easy to maintain. Basically, what would I have to do to keep this watch running for the next 30 years.
- Preferably budgeted under $75
Thoughts and questions:
1) Are there "better" movements that I should consider using that will fit this watch?
2) Since I want long-term function, would it be better to make this an automatic movement?
3) How long would a replacement ISA 2330 movement last and is it my best option to keep the watch original?
https://www.esslinger.com/isa-watch-movement-isa2330-103-quartz-movements/
New movement $15.95....quartz is not the easiest to work on esp if you don’t know what you are doing tools used on quartz movements are also very specific. So i suggest just a quick and easy movement swap. It’s the most basic thing you can learn if you are new to the hobby. Learn to remove stem, dial, and hands. Then re-assemble. You will need watchmaker non-magnetic screwdrivers/tweezers, hand puller, and hand setter.
Edited by saswatch88
Hi SASwatch is correct, as at the moment your knowledge is zero, now is the lime to learn the basics that being removing case backs, removing stems, removing hands and basicaly swapping the movement which if done correctly will last quite a long time and you would have gained the first foot on the ladder which is watch repair and servicing.
First pick up some reasonably priced screwdrivers case knife eyeglass (loupe) 5X and a medium priced pair of No5 tweezers this should enable you to change the movement. If you intend to continue with the hobby you can always add more and trade up in quality.
The tech data sheet contains very little information of use to you at the moment.
ahhh weasol I almost forgot case back opener duhhh, and def eye loop. Only thing i would say different is tweezer number 3 or even number 2 something with wider and tapered shanks. #5 is way too thin and mostly reserved for very fine detailed work. Someone experienced prob could use it for mostly anything but to a beginner it could mean many screws and parts flying across the room. OP just make sure they are non magnetic, because anything that becomes magnetized could potentially do harm to a quartz movement even more so than a mechanical.
Thank you both for you advice and information! I purchased the following items from esslinger today and they should be arriving next week. I am looking forward to working on this small project and having the watch back to working order. I already had the tool to take the back off and a pair of cheap tweezers that came with the amazon set purchased earlier. The one thing I didn't include was cleaning supplies because I didn't know if they were necessary for just replacing the movement. I chose to get the finger cots as a second option.
Watch Hand Remover Tool Compression Spring Style Watch Hand Puller
Delta Screwdriver Set 6 Piece Phillips and Flat Head Watch Screwdriver Kit
Watch Hand Tool Press for Inserting Installing Wristwatch Hands
100 Pieces Rubber Finger Cots Elastic Guards Medium Size
ISA Watch Movement ISA2330/103 Quartz Movement
Watch Battery Energizer 371 And 370 Replacement Cell
Looks good to me does the tweezer set come with a brass pair or are they anti magnetic?
Hi  Good,  looks comprehensive enough to start with. As saswatch says No 5 probably too fine, go with his suggestion.  If you are going to be changing batteries A plastic pair or ones with plastic tips but other than that you have done ok. One other thing  if you are working on mechanical watches consider a de-magnetiser as a potential future purchase.
Hi  Nows the time to start pick what looks like the simplest one and go for it. Remember you are not alone there are many members on here to help and are willing to help. When posting questions about a problem if you can always where possible quote the make and calibre of the watch and a pictures of the front and back, they go along way to help.  By The way  take pictures as you go for reference in case it all goes pear shaped.
On 1/13/2020 at 7:24 AM, WatchMaker said:
Just a word of caution before you get stuck in ... the finish on dials tends to be very fragile so don't use your new hand remover without some protection in place. You can get pro dial protectors but as a beginner some suitable soft plastic would be fine.
Watchmaker - I wish I would have read your comment earlier lol. I did in fact ruin the second hand with the tools. After ordering a new set of hands, the watch has been working perfectly! I love it and wear it daily.
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
