Replacing bell for gong striker/hammer
Andrzej541
Hello,
Hoping for some advice/thoughts re a French  slate mantel clock restoration that been undertaking..
Original Vincenti (13.4cm aperture fit) was in rough shape and as was for a Christmas present (already pretty overdue!!), no time to have stripped etc. Managed to get hold of a nice Marti however was a bell striker and original Vincenti movement was for a gong. Although both movements fit same aperture, the Marti is more substantial and square shaft on which striker sits on is thicker so simple swap over didn't pan out.
Basically trying to understand if there is a super fine square type file that could open out the square aperture of the Vincenti gong striker or a specialist out there that could supply a gong striker with wider square aperture.
Thanks for your consideration and apologies for any daft terminology as is the first time that have done anything like this. Images attached and if need some more info re shaft/aperture dimensions can advise. Thanks.
Andrzej
You don't have to get them from this source but it at least shows you the kind of variety of needles files available ... https://www.cousinsuk.com/category/needle-files ... along with the 'cuts' (coarse to fine) that exist.
If ordering from a site like ebay check dimensions and go for something with a fine cut.
Edited by WatchMaker
   they come in a set from any tool outlet.   they do wear out,  so buy new and no chineeze.  vin
     also;  their is a prodcedure to clean files.   "file card"  or wire brush. -  after or during fileing AND try not to file soft metal like aluminum     vin
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
