Vintage Elgin movement running FAST!
A vintage Elgin 15/0, Gr 559.  I took it down, cleaned and lubricated it and it is gaining 15 minutes/24 hours.  I have looked at the HS, it appears to be perfect, clean, flat, not magnetized (de-magged the movement X 3 already), and in position between the regulator pins.  Not hung on the center wheel.  Correct mainspring, and balance is not knocking.    I do not remember amplitude, but IIRC, it was above 22 which is O.K. by me with the movement.  Please give me some ideas as to how to correct this.  It doesn't seem like there are enough timing washers in the world to slow this down!
Thanks,
RMD
Thanks,
RMD
Did you put the hairspring under high enough magnification to see if any of the coils are sticking as its vibrating? Is hairspring also centered over the pivot, one side of the coils should not expand/contract any wider/narrow than the opposite side. Maybe dull or misshapen balance pivot causing high friction, did you get a look at the balance staff under a microscope. Get the amplitude again, if its low then these could be your issues since everything else checks out according to your post.
I looked at the balance/pivots/HS under the scope last night and will try to post pictures today.  The HS is as perfect as any I have seen.  The upper and lower pivots were straight and unfortunately flat on the tips.  I will have to look at some other Elgin Balances to see if this is normal for their manufacturing processes.
Thanks,
RMD
Thanks,
RMD
The American movements used flat pivots Swiss used concave pivots during the time. 559 guessing its somewhere in the mid-late 40s. The outer coil looks a little off to me did you check end/side shakes? From the pics the pivots seem fine but cant be too sure, they are not clear enough and would really need a higher magnification. When its running put finger pressure on the balance cock, with light pressure it should not stop the balance. If it does then end shakes is too small, if you press hard it should stop the balance if it doesn’t then you have too much side/end shakes.. This will tell you if any of the 2 balance staff pivots have issues, bent worn down too much etc. or even cracked balance jewels. You may be able to remedy with jewel pushing, adding spacers to balance cock, if you don’t have to know how to replace the staff. But a time trace would really be nice too.
Edited by saswatch88
A rather good LOT of NOS pocket watch hairsprings is on sale at ebay now, bereguet overcoils.
https://www.ebay.com/itm/LARGE-LOT-OF-NOS-ANTIQUE-ELGIN-POCKET-WATCH-MOVEMENT-HAIRSPRINGS-PARTS-REPAIR/392598089473?hash=item5b68ab6f01:g:74cAAOSwYS5d~QsB
 Your balance wheel looks undisturbed , should you take the other route ,to vibrate with longer HS, you can built a nicer looking balance complete.
Hope this helps.
  • Similar Content
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
    • The original 6139A manual is very clear in how to disassemble and how to assemble ...... step-by-step. However I haven't seen the 3169B manual, even in the Japanese version around, which clearly highlights the difference in center-wheel.   6139A Seiko Technical Guide.pdf 6139_A.pdf 6139A.pdf 6139b.pdf 6139B repair guide jp.pdf
