New Blood
MCofin
Hi Michael,
and welcome! If you don't want to worry about pinging and destroying watch parts (which can happen even when you're seasoned) get yourself some Vostok calibre 2409s to begin tinkering with. Extremely affordable and plenty on eBay, for example these which look pretty intact (but don't take my word for it). You might find my Vostok 2409 Service Walkthrough useful where I also explain why this movement is so special to me. Good luck and see you around!
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
