Ultrasonic
gary17
Umm wow 2 liters is wayyyy too much, you would be going through cleaning fluid like water on a hot day. I use small mason or glass jars with lids, maybe 4-8oz tops. I have different sizes. Bigger jars for main plates bridges, and smaller for wheels arbors, and i use separate jar for the barrel since there tends to be lots of grease and old oils in those I don’t want it contaminating the fluids for the more important parts jars. I have 4 of each size so i can do a 3/1 or 2/2 clean/rinse ratio. I stop cleaning when fluid remains clear. So use smaller amounts with more cleanings, you get a quite a few cleanings from each jar. As the first jar gets dirty I dump or filter if i can then i make the final cleaning jar my new first cleaning jar. I also put little mesh parts basket inside the jars. Now when you do this you need to fill the ultrasonic up with water at a bite higher level than the fluid in the jars but not too high where they will float or bobble. Frequency is important but doesn’t have much to do with size it all depends on the quality of the ultrasonic. There are larger ones out there with high frequency but they are really not needed and are extremely expensive. Get smaller ultrasonic with high frequency at an affordable price. Jewelry ultrasonics are good for this. I use them to clean tattoo equipment as well which will easily remove old bunked up ink in the crevices of the tubes.
Edited by saswatch88
Hi Gary Unless you are cleaning clock parts 2ltrs is as big  as you go, as mentioned jewelery cleaners at high frequency  are ok. Cleaning fluids Naptha ,Benzine. Isopropyl are expensive in quantity therefore the small jars in the machine containing the cleaning fluid are the sensible and economic way to go.  There are many opinions on the use of ultrasonic cleaners as there is fluids and cleaners you will get many of them on here. how you do it is down to you in the end.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
