Hairspring Issue Lemania 873
Dico
Hello All
Im working on regulating a Lemania 873 chrono which was fully serviced about 2 years ago. I have the beat to under 0.8ms, but the speed is erratic reading -400 plus and moving the regulator doesn’t do much. Despite the -400 reading the watch is running fast. I figure I have a Hairspring problem and noted the large loop in the photo between the beat and regulator levers. Does something look off here that needs to be corrected? Any help is greatly appreciated!
Hi The balance spring should be concentric, that loop should not exist, there should be a smooth curve right up to the pinning point. You will have to manipulate the balance spring to achieve the smooth even curve then set about regulation,  For reference take a look at any other watch and observe the balance spring shape and operation so as to familiarise yourself as to what you have to acheive.
Oops. It looks to me like the regulator pins have moved past where the terminal curve starts. Then when attempting to move back into the terminal curve they have caught it and bent it badly. It's going to need some very careful unbending.
End section ( between stud holder and regulator pin) of hairspring is deformed.
Possibly hairspring is grabbed in the slot of regulator arm.
Move regulator arm and stud apart, this would streigten the said section, you can try to give a shape.
Edited by Nucejoe
Move stud holder reg pin apart. Shape HS.
Hi  you have been given two clear pictures of what to achieve, Probably best to remove the balance and spring, and take the spring off the balance. First check the balance rim for a mark denoting the stud position relative to the impulse roller, If no mark leave the spring on the balance and support the balance in a stake taking care to protect the roller, reform the balance spring as show in the pictures maintaining the flat profile once done mark the balance rim (marker pen fine) with a dot for future reference.  refit the balance to the cock and refit to movement  now start the regulation. Check the beat error as this is likley to be out   Lemania lift angle = 50.
Hi  you have been given two clear pictures of what to achieve, Probably best to remove the balance and spring, and take the spring off the balance. First check the balance rim for a mark denoting the stud position relative to the impulse roller, If no mark leave the spring on the balance and support the balance in a stake taking care to protect the roller, reform the balance spring as show in the pictures maintaining the flat profile once done mark the balance rim (marker pen fine) with a dot for future reference.  refit the balance to the cock and refit to movement  now start the regulation. Check the beat error as this is likley to be out.  The lift angle for Lemania 1873 = 50.
Thank you all again for the great feedback! I attempted to straighten the loop and the Hairspring completely detached from the collet. Is it possible to reattach this? Is it even worth it to use this same Hairspring given then deformation? Any suggestions on where I can source a new one if this one is not salvageable?
66afe9660fd0fe8082db5875f1dda182.jpg5dea1f9a8523aa2a82a98e0b46525f78.jpg8c8cfcf3f6e97e8ece352e96102ff9cb.jpg
Hi  for the sake of practise I should have a go at re curving the old one and if sucessfull  re pinning it to the cock and try it.   If it ends up knackered you have lost nothing. Sourcing another spring or balance complete cousins uk  or ebay for a donor movment depending on your location Esslinger , Jules Borel  in America or Perrins, Canada.  good luck
Good advice I’m giving it a shot here to see if I can correct it. I’m working on straightening the curve first but I’m not sure how to reattach the Hairspring. Does this pin just pull out ?5078d844fb2156bc278ccd3eaf75b3fd.jpg
Has the HS broken off from the stud? Is there a small length of HS still in the stud? Is so, if you reattach then the length will change. So regulating may be difficult. Plus the terminal curve will need adjusting so it’s between the regulating pins. It’s a tough repair. Dynamic poising may help correct for the too short HS. But to be honest, replacing the balance assembly might be easier.
Yes, the HS is pinned to the stud with a tiny brass pin.  As others have noted, repinning the HS will effectively alter the length of the HS thus altering the timing of the escapement.  Its good practice, but you may not be able to regulate the movement following your efforts.  As I said though, good to know how to do this particular repair.  Good Luck,
RMD
Hi Dico   as mentioned  it is just pinned to the stud, press the pin out and remove the remainder of the broken spring. Stand the balance on the cock in the correct orientation and manipulate the spring end into the hole and re fit the pin just enough to hold it in place, adjust the outer curve so it sits between the regulator pins now re bit the balance. The first thing you will notice its now out of beat due to the re pinning , the roller and impulse jewel will be in the wrong place. If you can reposition the stud arm you may over come this a little , The rate of the watch will be fast because of the shorter spring but as this is purely for practise no matter. To return the watch to its former glory It will need either a new spring or balance complete (with spring attached and timed). but the lesson learned by re fitting will stand you in good stead when fittin the new balance..   Cheers
Yes, just pull out the stud pin.
Normally you can still regulate if HS is shortened up to a mm or two. Just reshape the end curve reattach HS to the stud, repin or use glue.
Mobile stud carrier easily lets you keep impulse in beat.
Good luck
Thank you all very much! I decided to get a new balance assembly as I couldn’t quite bend the terminal curve exactly uniform. Wasn’t easy to find but I was able to source one on eBay. Very helpful guidance from the members here very much appreciate the help!
Have you checked prices,  Chrono grade balance is real expensive.
12 minutes ago, Dico said:
Yeah about $320 US . This if the one I found
htps://rover.ebay.com/rover/0/0/0?mpre=%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F112015850622
The price implies Chrono, link dose not say.  I say lets leave it for the last resort.
I am pretty sure the balance you got would regulate just fine. True, a nicely uniform end curve is not only pretty but renders regulating easy , however not a neccesity for proper oscillation, in other words it dose not have an essential role.
As long as the curve is near concentric with other circles of the coil, you are Okay. Regulate first then get the inner coils concentric. I,ll be happy to work with you to get the thing running.  I can,t tell if this balance is a Chrono grade but it be a shame if it is  and you can fix it, but let it go to waste.
Best wishes
Man you guys are great! Ok I’m going to try and use the one I have and see how it regulates. So to remove that pin and get the Hairspring re-attached do I simply pull it with a tweezer or push it from the other side?
I used to get the pin out like you said, then bought me a cheapy long nose pliers and made my life easy. If you are going to order one, let us show you a suitable one.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
