My first Marlin
You can try repairing the crystal yourself. Walmart sells a headlight restoration kit that comes with everything you need to restore a plastic watch crystal. I've used it and it works amazing. The kit is made by Rustoleum, so there may be other places to purchase this.
https://www.walmart.com/ip/Rust-Oleum-Headlight-Restoration-Kit-1-Pack-12199-040/147633275
2 hours ago, MyFavoriteObsession said:
Thanks for the suggestion. I liked that '77 Marlin you cleaned up, it looks great. Mind if I ask how you removed the gold tone on the bezel?
On the '77 it was silver tone from the factory. Removing gold coloring isn't easy on any material without ruining it.
The dial code is 2606802476. I was under the impression that codes beginning with 2 were Marlins and codes beginning with 1 were Mercuries, though that's just from random internet claims.
Sprites begin with 2 as well so the one single digit is not enough to determine the model.  Best is to have a catalog from the year in question.   Of course those are not easy to come by but, I do have a collection of them. Anyway, one key feature of a Marlin made from 1963 to say 1983 or so is the Water Proof \ Water Resistant or wave logo on the dial.  Of course Sprites have this as well and so do the 21 Jewels.  But no Mercury will have that on the dial. A Mercury will also not have that on the case back either whereas the others will.
I will check for the part latter today.
1 hour ago, JerseyMo said:
can't find the dial code in any of the reference guides I have.  These books are limited to US sold models so the only way to go is to physical match up.  Show me a pic of the back of the case.
Thanks for checking. Inside reads, "Case, Great Britain, Timex". The stem crown from the '67 Mercury fits this watch but if this black dial is not a Marlin then I'll probably set it aside for parts and continue the search.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
