My first Marlin
You can try repairing the crystal yourself. Walmart sells a headlight restoration kit that comes with everything you need to restore a plastic watch crystal. I've used it and it works amazing. The kit is made by Rustoleum, so there may be other places to purchase this.
https://www.walmart.com/ip/Rust-Oleum-Headlight-Restoration-Kit-1-Pack-12199-040/147633275
2 hours ago, MyFavoriteObsession said:
Thanks for the suggestion. I liked that '77 Marlin you cleaned up, it looks great. Mind if I ask how you removed the gold tone on the bezel?
On the '77 it was silver tone from the factory. Removing gold coloring isn't easy on any material without ruining it.
The dial code is 2606802476. I was under the impression that codes beginning with 2 were Marlins and codes beginning with 1 were Mercuries, though that's just from random internet claims.
Sprites begin with 2 as well so the one single digit is not enough to determine the model.  Best is to have a catalog from the year in question.   Of course those are not easy to come by but, I do have a collection of them. Anyway, one key feature of a Marlin made from 1963 to say 1983 or so is the Water Proof \ Water Resistant or wave logo on the dial.  Of course Sprites have this as well and so do the 21 Jewels.  But no Mercury will have that on the dial. A Mercury will also not have that on the case back either whereas the others will.
I will check for the part latter today.
1 hour ago, JerseyMo said:
can't find the dial code in any of the reference guides I have.  These books are limited to US sold models so the only way to go is to physical match up.  Show me a pic of the back of the case.
Thanks for checking. Inside reads, "Case, Great Britain, Timex". The stem crown from the '67 Mercury fits this watch but if this black dial is not a Marlin then I'll probably set it aside for parts and continue the search.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
